Drag Racing Tech
welding in a cage?
Old May 5, 2009 | 09:28 PM
blockheadnic's Avatar
Default welding in a cage?
When you weld in a roll bar over the rear above the axle do you remove the fuel tank. this is on a steel tank.
Old May 5, 2009 | 10:12 PM
Camaro396's Avatar
I would drop it. It only takes 30 seconds to do. We dropped the tank when doing Trigger's bar.
Old May 5, 2009 | 11:45 PM
SOLO Z's Avatar
some people leave it in some drop. it it is up to you, if you want to take the time to do it or not. I agree with camaro396 drop it. it only takes an extra min
Old May 6, 2009 | 12:10 AM
JRracing's Avatar
Take it out to be safe...
Old May 6, 2009 | 09:14 AM
RAACCR's Avatar
To do a cage on a unibody chassis correctly, you should weld the bar to a plate on the floor, and thru-bolt the plate to another plate on the bottom side of the floor...so yeah, the tank needs to come out to do that.
Old May 6, 2009 | 09:42 AM
I wish it only took 30 seconds.
looks like its coming out then, thanks for the comments.
Old May 6, 2009 | 09:50 AM
Camaro396's Avatar
It no joke took us maybe a minute...but then again this car doesn't have a catback, heat sheilds, or any other bullshit on it. Just un bolt the two rear strap bolts..You don't have to completely take it out. Just unbolt the straps and let it drop down as far as it will go.
Old May 6, 2009 | 09:55 AM
z28rob18's Avatar
we went to drop mine but it took us a half hour and we gave up couldnt get the exhaust out of the way. just stuff a wet rag under where we were weldin and stood close with a hose.
