1/4 Times with 100 Shot
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I went out to Pheonix this weekend for the PSCA Finals and I took my car out there for some Test and Tune between rounds.
Sat.
1st Run
1.552 60ft
4.376 330ft
6.735 1/8et
104.593 1/8 mph
10.502 1/4et
130.282 1/4mph
2nd Run
1.541 60ft
4.364 330ft
6.728 1/8et
104.283 1/8mph
10.500 1/4et
130.298 1/4mph
3rd Run
1.568 60ft
4.372 330ft
6.730 1/8et
104.639 1/8mph
10.495 1/4et
130.529 1/4mph
The first runs were done with no NOS off of the line because I wasn't sure what to expect.So I decided to pull out 2 plugs which they both seem to be a bit lean.That jetting was .52 NOS .32 Fuel so I put in a .35 fuel and finally started leaving on the NOS.
4th Run
1.430 60ft
4.225 330ft
6.581 1/8et
104.601 1/8mph
10.352 1/4et
130.282 1/4mph
5th Run
1.466 60ft
4.256 330ft
6.614 1/8et
104.502 1/8mph
10.384 1/4et
130.263 1/4mph
6th Run
1.537 60ft
4.361 330ft
6.723 1/8et
104.452 1/8mph
10.491 1/4et
130.382 1/4mph
7th Run the bottle was getting low
1.524 60ft
4.369 330ft
6.744 1/8et
103.863 1/8mph
10.532 1/4et
129.654 1/4mph
8th Run nearly empty bottle
1.517 60ft
4.367 330ft
6.779 1/8et
101.866 1/8mph
10.648 1/4et
127.070 1/4mph
Sun
1st Run fresh bottle New Best
1.461 60ft
4.238 330ft
6.582 1/8et
105.221 1/8mph
10.327 1/4et
131.174 1/4mph
2nd Run
1.489 60ft
4.277 330ft
6.624 1/8et
104.956 1/8mph
10.383 1/4et
130.536 1/4mph
3rd Run
1.576 60ft
4.377 330ft
6.722 1/8et
105.275 1/8mph
10.466 1/4et
131.116 1/4mph
4th Run
1.502 60ft
4.317 330ft
6.676 1/8et
104.514 1/8mph
10.446 1/4et
130.209 1/4mph
5th Run
1.626 60ft
4.452 330ft
6.816 1/8et
104.399 1/8mph
10.592 1/4et
130.100 1/4mph
6th Run I guess the bottle must have been near empty
1.512 60ft
4.375 330ft
6.803 1/8et
101.346 1/8mph
10.698 1/4et
126.219 1/4mph
The rest on the motor
7th Run
1.655 60ft
4.720 330ft
7.270 1/8et
96.434 1/8mph
11.336 1/4et
121.413 1/4mph
8th Run
1.726 60ft
4.772 330ft
7.300 1/8et
97.323 1/8mph
11.336 1/4 et
122.313 1/4mph
9th Run
no slip the tower said that they didn't have it but told me that I ran a 11.35 at 122
All runs were made on complete stock fuel system,stock Rear End with 4.10's and Eaton Posi on 28x10.5 ET Drags,and stock short block.
Race weight is 3160#'s with me in it.
Sat.
1st Run
1.552 60ft
4.376 330ft
6.735 1/8et
104.593 1/8 mph
10.502 1/4et
130.282 1/4mph
2nd Run
1.541 60ft
4.364 330ft
6.728 1/8et
104.283 1/8mph
10.500 1/4et
130.298 1/4mph
3rd Run
1.568 60ft
4.372 330ft
6.730 1/8et
104.639 1/8mph
10.495 1/4et
130.529 1/4mph
4th Run
1.430 60ft
4.225 330ft
6.581 1/8et
104.601 1/8mph
10.352 1/4et
130.282 1/4mph
5th Run
1.466 60ft
4.256 330ft
6.614 1/8et
104.502 1/8mph
10.384 1/4et
130.263 1/4mph
6th Run
1.537 60ft
4.361 330ft
6.723 1/8et
104.452 1/8mph
10.491 1/4et
130.382 1/4mph
1.524 60ft
4.369 330ft
6.744 1/8et
103.863 1/8mph
10.532 1/4et
129.654 1/4mph
1.517 60ft
4.367 330ft
6.779 1/8et
101.866 1/8mph
10.648 1/4et
127.070 1/4mph
Sun
1.461 60ft
4.238 330ft
6.582 1/8et
105.221 1/8mph
10.327 1/4et
131.174 1/4mph
2nd Run
1.489 60ft
4.277 330ft
6.624 1/8et
104.956 1/8mph
10.383 1/4et
130.536 1/4mph
3rd Run
1.576 60ft
4.377 330ft
6.722 1/8et
105.275 1/8mph
10.466 1/4et
131.116 1/4mph
4th Run
1.502 60ft
4.317 330ft
6.676 1/8et
104.514 1/8mph
10.446 1/4et
130.209 1/4mph
5th Run
1.626 60ft
4.452 330ft
6.816 1/8et
104.399 1/8mph
10.592 1/4et
130.100 1/4mph
1.512 60ft
4.375 330ft
6.803 1/8et
101.346 1/8mph
10.698 1/4et
126.219 1/4mph
7th Run
1.655 60ft
4.720 330ft
7.270 1/8et
96.434 1/8mph
11.336 1/4et
121.413 1/4mph
8th Run
1.726 60ft
4.772 330ft
7.300 1/8et
97.323 1/8mph
11.336 1/4 et
122.313 1/4mph
9th Run
Originally Posted by Coach 02 A3 Z/28
Nice runs man!
Great practice for ya this past weekend. Great to see some else to make alot runs over a weekend.
Coach
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Coach
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by W8N2SQZ
Hey Ninefinger,
It was cool meeting you. Good luck with that thing and keep us posted if you go back to the track.
Glenn
Glenn
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Yep, I keep tellin' people these stock fuel systems will do more than they think. Some folks think it's maxed out with heads/cam running NA. ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Sweet times and killer MPH.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Formerly 4mulaJoe
I for one am surprised the stock fuel system is keepin up on the dope. In the pic below you can see what happened to a firends car with heads/cam and a 125 shot when the fuel pump couldn't keep up
http://torqueaddicts.com/media/aj/sl...ock%20001.html
4mulaJoe, did he have a fuel pressure gage? Dry shot or wet?
With any nitrous setup, it's best to start with the small pills and work your way up one step at a time while carefully Autotapping along the way. By doing this you should be able to catch it starting to run lean before it's too late. A fuel pressure gage is also a very good idea in any high HP or power adder setup.
Originally Posted by LIL SS
You don't even need a fuel gauge if your using a fuel pressure safety switch that is properly set up.
Formerly 4mulaJoe
With an M6 (more efficient drivetrain) in a 98 or an '01-'02, I can see maybe 550 RWHP (it's been done before.) 570 is certainly pushing it though!
I wouldn't have tried that without some careful testing to confirm that it would work, such as what I described in my last post.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Nah, different pumps too. Don't ask me why. I don't see why they need injectors or pumps as big as what they have in any year to support stock power levels...but I'm glad they come that way. I'm making roughly 425 RWHP and I'm not even thinking about the fuel system at this point.
<----to GM for the fuel systems.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
