Drag Racing Tech
Couple quick pics of my Camaro project
Old 12-07-2009, 11:25 PM
  #81
Philly Fakeout!
BadCompanySS's Avatar
Thanks guys. If I can ever get a block, I can get a motor put together. I have the Wiseco pistons and Callies Magnum crank here. Still waiting on the Howards rods and LSX block.
Yeah the car will have a belt drive fuel pump. I couldn't find an electric pump I felt good about with alcohol. On the gear drive issues, I've heard issues with the bushings but nothing with the blowers. No more racing that the car will see in a year, I don't think it will be to big of a problem. I will just order a couple extra sets for when they need changing.
I changed names for the thread since I have to keep up with my post count for work. It's just easier to count work stuff using this name here since this isn't really a Texas Speed project.
Old 12-29-2009, 10:36 PM
  #82
Josh@KY-Turbo's Avatar
What Wheel Size and Back Spacing are you running? I am running a 9" raer that i snarrowed 6" also.
Old 12-30-2009, 10:42 AM
  #83
Philly Fakeout!
Rear wheels are a 15 x 10 with a 4.5" BS from what I can remember. I'm going to pull the spacer off the wheels and mill them another 1/4" or so to bring the wheel in a little more.
If you like the D10s I have the original rear wheels I bought that I need to get rid of. They are for a 6" narrowed rear. I'll make you a smoking deal on them!
Jon
Old 01-24-2010, 12:07 PM
  #84
Philly Fakeout!
Little update and info. on my build. I've been kicking around the idea of putthing a hard top on my car and ditching the T-tops. Seemed like a good idea to get rid of the glass and knock out a little weight going back with the fiberglass top. Then after seeing Top Kempf's car, I got the bright idea to holesaw under the top to get some additional weight how where it wouldn't really show...
Pulling the sail panel off is a job in itself. Getting it off without cracking it was a chore and a half! Then it was off to start holesawing. I don't know how many have ever cut with a 3 1/2" hole saw but it takes a lot of drill to run it through metal. The problem with that is when it bites and stops the bit the drill likes to try and break your wrist! haha... Yesterday was a long day but this is how far I got. Planning on trying to finish up today. I can tell you for sure, when this little project is done that holesaw will be going in the trash so I can ever get a bright idea like this again!
The best part, if you look at the last pic you can see the weigt savings so far from the holesawing!
Jon
Old 01-24-2010, 01:28 PM
  #85
kmracer's Avatar
hhaha, gotta love it!
Old 01-24-2010, 03:53 PM
  #86
Philly Fakeout!
Ended up saving a little over 4 lbs.
Old 01-24-2010, 05:52 PM
  #87
DanZ28's Avatar
I saw the other car do that, now yours, I was trying to ignore it though as it looked like a big PITA but I may have to motivate myself to do it now, 16-17 lbs. When I first looked at that scale Pic, I thought it said 212.5 pounds, lol.
BTW, your car is looking great.
Old 01-24-2010, 07:56 PM
  #88
MrElectric03's Avatar
My car sits outside...lol it would be filled with water if I did that
Old 01-26-2010, 04:08 AM
  #89
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
After seeing Tom's car I've been thinking about doing that also. My car is garaged, but rain would scare me. With the roof panel glued back on I don't think there would be any issues?
Old 01-26-2010, 12:35 PM
  #90
00SS4780's Avatar
Sweet build!!!
Old 01-26-2010, 10:52 PM
  #91
Philly Fakeout!
No way would I do it again. I think the hard top will save some weight but the holes were probably a bit overkill. We'll see how much that saves. But for how long it took to drill holes for 4 lbs I just won't eat one raceday!
Old 01-26-2010, 11:05 PM
  #92
95CamaroLS1's Avatar
Ya i agree i think the black hood looks sick
Old 01-27-2010, 12:18 AM
  #93
DanZ28's Avatar
Ok, I'll re-think my motivation again . I'll just see in the end where I'm at weight wise. I have to weigh 3500# anyway but I would rather add weight then try to figure out how to remove it.
Old 02-21-2010, 02:32 PM
  #94
Philly Fakeout!
No more T-tops! Converting it to a hard top. Finishing up wet sanding the roof today and hope to have it painted and put on in the next week or so.
Old 02-21-2010, 02:34 PM
  #95
Philly Fakeout!
Also a little teaser of what's waiting to go on the motor when I get everything to put it together! Seems like it's always waiting for something. If rods ever come in, we'll put this thing to use!
Old 12-15-2010, 11:18 PM
  #96
Philly Fakeout!
It's been a while since I updated this so I thought I'd post up some pics. It's been a SLOW process but it's at least making progress. I usually only get to work on it on the weekends since the car is 2 hours from where I live.
After a lot of contemplating, I decided to pull the new 8.50 cert cage out and go ahead and build a 25.3 cage in. All the interior will end up being redone all over again. I can tell you the 3M spray glue is a PITA to get off with Ozite carpet!
Here's a couple pics of the floor of the cage coming together. Got the hard top put on as well.
Getting the MadMan Torque Arm setup
Old 12-15-2010, 11:19 PM
  #97
Philly Fakeout!
Sorry the pics suck. They are all off my phone.
Here's a couple goodies and mock up pics that have shown up in the mean time as well.
Old 12-15-2010, 11:25 PM
  #98
2002sscamaro's Avatar
nice build!!!
Old 12-15-2010, 11:44 PM
  #99
I have talked my self into and out of doing a 25.3 cage in my 02 Formula a dozen time already. Looks killer so far pimp.
Old 12-16-2010, 07:41 AM
  #100
SS4Luck's Avatar
wow man that car looks nasty! It will be awesome if it ever comes along like your talking about lol
Quick Reply: Couple quick pics of my Camaro project
