The Rookie vs. the 25.5 project.
Thanks for all the kind words of encouragement.
When I picked up this car up my intentions were to practice on this one, and do it for real on another one… I already have the other car. But once I got started I just kept going and this is where I’m at. I’m still going to build the other car… Probably set it up for a N/A class and race it locally. I’ll make them look the same but only one will have some real teeth…
7 Second Club
i like your mid-plate brace... nice and creative and sturdy... i'm one of the guys that has a bar running under the windshield and i recently had to put a engine limiter on to keep the forward and backward movement to a minimum.
i've seen a few of madmans cars where he welds the mid-plate into the firewall also, which is also neat...
looks like your doing a good job.... you're bracing the **** outa that thing in the back... make sure you dont neglect the shock tower bars and for a 25.2 you'll need one more diagnol bar to make an "X".
7 Second Club
something else i was going to mention.... with those 2" drop spindles you'll either have to get the rear of the car really low and get a madman torque arm that has lots of adjustment, clearance the tunnel, and get some extra long LCA brackets (the BMR ones arent long enough) to get the IC of that car back where it needs to be or sell the drop spindles and get a standard height spindle.
i did the same thing on my car, however at the time i wasnt ready to make all the other modifications to make them work so i talked to burkhart chassis about making me a set of stock height spindles that fit the 3rd gen brake kit.... pm me with any questions about that if you need to.
I’ll post up some more progress pics tonight. I don’t have much time to post during the day, so this will more than likely be a build thread for the night shift… But if any of the Pros or otherwise, see something I missed, or something I can do to make it better or safer, please speak up… We can all learn something.
Thanks for the info. I have a few more bars to put back there but I can't until I modify my tunnel around the rear torque arm mount… It hits the floor right now. I’m going to change that all around, soon.
#32
Thanks. And yes, I might wanna pick your brain about that. Right now, the car sit low, but will it be low enough???... I don't know. Lots and lots of mock up to do...
#34
Here are a few pics of the car when I had it sitting on it's wheels during the cage install. As I said earlier, the rear tires are MT 325's, the wheels are 10" Weld Magnum. Up front, I'm running 3.5" Weld billet's on Good Year 26" tall tires. I'm happy with the look but is it gonna work at the track?... That's another story. Extending the LCA brackets and opening up the tunnel for torque arm clearance is easy so I "should" be able to the IC angle that (ty ty13) mentioned above.
![The Rookie vs. the 25.5 project.-picture-232.jpg](https://ls1tech.com/forums/attachments/drag-racing-tech/194476d1469142958t-rookie-vs-25-5-project-picture-232.jpg)
This is the tranny I picked out for this project. I'm no tranny expert but it appears to be built the way I needs to be. It's a Abruzzi "Mack Daddy" with all the SFI stuff so I don't think I have to run a shield. I haven't picked a converter yet, but I'll probably go with a Neil Chance. 9.5" bolt together unit set-up for the "trainer engine." Trainer engine... I guess I should expound on that a little.
![The Rookie vs. the 25.5 project.-picture-242.jpg](https://ls1tech.com/forums/attachments/drag-racing-tech/194477d1469142958t-rookie-vs-25-5-project-picture-242.jpg)
I'm been out of drag racing for about 20 years. I haven't been out of motor sports, just "asphalt drag racing." Things have come a long why since then, so I need to learn how to drive a small tire call all over again. I also need to learn how to set this car up and get my NHRA drivers licenses. So what I've decided to do, is put a small motor in it first, just to set everything up, learn the car, and get my drivers licenses. Oh I'll put something interesting in there to make it fun, but nothing over 1000 HP to start. What would that be?... 9-ish second car? 1000 HP @3400 lbs with a Glide... That should put me in the 9's somewhere... @ maybe 150 MPH. <(?) For this rookie, that's a good place to start.
![The Rookie vs. the 25.5 project.-picture-235.jpg](https://ls1tech.com/forums/attachments/drag-racing-tech/194475d1469142958t-rookie-vs-25-5-project-picture-235.jpg)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#40
Thanks! And yes, doing this sorta stuff for other folks is a plan (If it turns out well and there is a demand for it in my area) I already have TWO jobs, so I'll have to get more help if that happens. But right now, it's all about the "fun" of it.
