11 Sec. Bullet Proof M6 F-Body Build List
Hey Guys. Since our cars have so many weak links I've been thinking alot about how to make it "basically" bullet proof. I understand nothing is unbreakable
After I was done with everything for the drive train I thought I'd add some basic performance parts to get the car reliably into the 11's.
I was hoping some real drag guys could comment on this "11 second bullet proof f-body build". I didn't want newbie's posting up telling me to add a K&N Filter or Smooth Bellow to the list if you're following me
. Its really just a very basic build with basic average pricing. Only thing on the list that is used is an LS6 intake manifold. I understand with lots of searching you could get a lot of these items cheaper if you found them used, but for simplicity sake I chose to list "new" prices.
The only item I was really on the fence about was the Stage 2 Tranny Build by Tick. With the modifications listed you would have somewhere around 400ish rwhp give or take. Some cam only guys I know run around 380ish or more at the wheels and some with wild cams run well over 400. Since these aren't crazy amounts of power I'm not sure if you would really need to get the stage 2 build since it can handle 700 pounds of torque which we would be no where near. Thanks for your time or any input. This build list is a sort of side hobby thing I'm working on that I'd really like to get nailed down.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![](http://i469.photobucket.com/albums/rr57/MapleBoarder78/build.jpg)
OK so, first I would consider a spooled rear, and go with true slicks, an M9 car shocks the driveline pretty hard. Gearing is everything in a M6 car, you want it stick, but not bog too bad.
Not sure about how much you plan on driving this car on the street, also consider some front end parts to lighten the load. didnt see any mention of lower control arms but im assuming youre using um.
Leave the Koni's to the roadracers. For drag racing it would be better to go with some adjustable Strange or QA1 shocks, at least for the rear. Both of those work just fine on the street. Being a stick car, you'll need to control the hit to the rear tires, especially running a DR, and the Koni's aren't going to cut it IMO.
You'll def need a driveshaft safety loop.
Subframe connectors would help alot.
Make sure to get adjustable LCA's so you can center up the rearend.
I'd run the trans until it breaks, then do the rebuild.
Do you already have an aftermarket shifter?
Have you done any weight reduction on the car?
That's all I can think of for now.
Mike
Mike
Mike
Mike
Yeah I'd definately ditch the Konis for some Strange or QA1s. I dropped 4 tenths on my 60' by swapping from Konis to Strange DAs in front and SAs in the rear. Other than that it's a pretty decent list.
I was reading the NHRA rules the other night because i was trying to make sure my car would pass insoection at the LSX shootout, and if i read them right then anyhting running faster than a 13.99 is supposed to have a drive shaft safety loop. And anything under 11.499 is supposed to have a 6 pt cage i believe.
So after all the comments I'll be adding a drive shaft safety loop and sub frame connectors. Only reason I'm not adding drag shocks and springs is that the list is aimed toward road racers and drag guys, so anything on the list needs to benifit both sides.
