M6 TrueTrac roll call *Update spool>truecrap
I cracked the case on my Tru Crap, twisted the driver's side splines, and twisted the driver's side wheel studs on my second trip to the track with boltons and a cam. I now have a spool with 4.30s, 35 spline axles, and 1/2" ARP wheel studs.
Internet Mechanic
I have a car in my garage now, has one of those POS diff's in it. h/c car with a nitrous tune, made about 440 rw with the n/a tune, broke after 5 runs n/a (nitrous wasn't workign so we just ran it n/a to see what it would do)
I have another car, that's broken 2 of those things, both with less then 5 passes on them.
They are JUNK, I tell people all the time. Sounds like another victim of these POS diff's I'll say it 1 more time, putting a tru-crap in a 12 bolt/9 inch/S60 is pretty much putting you right back to 10 bolt strength, I'm starting to think they may actually be worse then a 10 bolt. Don't do it.
#36
This would save some weight too. When I put the 4:30s in from my 3:73s. The truetrac with the ring gear bolted on was 57#s. I see spools for the s60 listed at 13.2#s, So it could maybe save 30-40#s?
And I could go to more gear like it wants. 4:88s for right now going mid 120s. But Im porting some 243s, and 4:56s would be needed.
wait I have my s60 373 gears here at the shop. I'll go weight the ring gear with bolts......
.....edit, just the 3:73 ring gear is 9.8# with bolts its 11.0#
So the truetrac is 46#
going to a strange "lightweight" pro race spool (13.2#) would save 32.8 #s![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ok so guys running a spool what kind do you have. I take it this strange Pro Race "lightweight" spool is steel. The alum ones I dont think would hold up, lol
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#37
I just killed my Alum this week end So i say no alum. Mine was put in befor the 4.56 swap and with the 4.56 gear and 7k dump no good. Get the Pro race spool that is what i am going to know and the nice part is strange is only 45 mind aways from where i live on a bad day haha. And hell yeah get them 4.56 gears th heads will love it mine did.
#38
Race your car!
Spool it. I've driven with one on the street, it's not that bad, tires chirp a little around corners, other then that it's fine. Granted, if you're ripping around curvy roads and whatnot you probably won't like it, but that's about the only time I think you'd really notice.
FWIW I have a moser lightweight steel 33 spline spool in my 12 bolt, no problems.
#39
Ya, steel spool for sure...
The 4:30s whine a bit, I'm not that hard on them right
But this setwill always be that loud now right? If I check them out and move them a little setting up the spool can any change they could get quiter??? There a strange set, and the only 4:30 set I found for the 3:54-4.10 carrier size. The other in 4:30-5:88 or somthing for the s60. The gear lash they listed at .008-.010 street (not 100% sure). But the Track spec was .006-.007 I was right in the middle, and used the pinion shim strange used on there setup of the 3:73s. The pattern marked were they wanted, witch was a little on the outside of the heel? IIRC..
If I'm just putting a spool in with the same gers I shouldn't have to mess with the pinion gear at all. The spool is cheap, and I just need carrier bearing for it, it dosn't use shims. everything else is fine.
But I would like to get it quite agian, so maybe change the ratio? hum...
I looking at the gear/mph chart on http://www.f-body.org/gears/
My 28/10.5/15S ETdrags Do think I put them in has a 29.0 tire, I think thats close to what there going in my car. II know on my 28.0 DR that don't grow I can tell its more RPM. What dose it look like for your trap/rpm for you guys on that tire. 29.5 even 30.0? you do have to clearence about 1inch around
RPM-MPH........../ 29.0 /4:30s
6000 120
6100 122
6200 124
6300 126
6400 128
6500 130
6600 132
6700 134
6800 136
6900 138
7000 140
RPM-MPH / 29.0/ 4.56
6000 114
6100 115
6200 117
6300 119
6400 121
6500 123
6600 125
6700 127
6800 129
6900 131
7000 132
6000 120
6100 122
6200 124
6300 126
6400 128
6500 130
6600 132
6700 134
6800 136
6900 138
7000 140
6000 114
6100 115
6200 117
6300 119
6400 121
6500 123
6600 125
6700 127
6800 129
6900 131
7000 132
#40
Race your car!
Figure the tire at abotu 29 inches, I measured mine when new, they were about 28.2 (circumferance divided by 3.14159) and I have about 7/8 of an inch all the way around the tires, and at 142+ they don't rub at all, so that's probably about an inch of growth at the most. When I measured them, I had 20 lbs of air ni them as well, air them down and they look smaller, but expand more (example, during the burnout the back of the car actually rises a little)
You're right at the point that a 4.56 will be perfect, as I don't think you'll see more then 132 mph unless you're making 480 to 500 rwhp and have a potato chip race weight.
