M6 TrueTrac roll call *Update spool>truecrap
#84
Ive had my Tru Trac in a 9" for 3yrs now....not one problem...before the auto swap id leave at 5k with the nitrous engaging immediately, no super impressive 60fts, just 1.60s. But I was having wheel hop through the 60ft. Guess I got lucky with mine. Ive been kicking around the idea of pulling it out and selling it and going to a spool for lighter weight.
#85
My Detroit Locker 9" is incredible, I don't know why some of you guys are trashing them. Strength is almost that of a spool without some of the spools negatives. Occasionally you get a click on lockup but no big deal. I've had mine for 6 or 7 years no issues, with 5,000+ rpm launches.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I will say that I thought about switching to a spool because my locker is ~25lbs vs a spool thats what 8-9lbs.
#87
#88
Ok, well here's your instance of a S60 35-spline TrueTrac taking a dump. I haven't checked the housing yet but last weekend at the shootout in BG I had only one tire spinning during burnouts. I could hear the rear end whining in the car during the burnouts. Then as a result I would be white smoking the tire that didn't get hot during the burnout when I launched.
This rear end has seen maybe 10 passes on 28x10.50 MT ET Drag S slicks never cutting below a 1.48 60. It's an M6 with a 3,615 lb race weight. I'll probably pull the cover this weekend and start looking for garbage. I'll post pics later on what I find.
I've been told to go to a spool and I'm 3/10 away from getting my first 9 sec pass. For you guys that went to a spool, what unit should I look for to use in the S60? I need to get my 60's down to get that 9. TIA, Kyle.
#90
#92
I don't know but I just couldn't wrap my head around having my car handle like that, and that's why I went with the truetrac. I can't stand pushing around a fucked up grocery cart. I also understand that MWC makes very little off of every rearend they sell so I went with their recommendation as I didn't feel they were trying to sell me something I didn't need.
MWC also stated that they have not had a single truetrac 35 spline failure in an S60 that they shipped out to one of their customers and I believed them. They have sold a **** ton of them. Besides, there is a excessive noise disclaimer on the instructions included with the S60 if you read it so don't be surprised if your S60 makes a little noise, they told you so.
If I had gotten a spool I would probably have been one of the ones complaining about my tires chirping around corners with excessive wear and not being able to get into a 90 degree parking spot. IMHO spools aren't for everyone and if you're gonna buy, buy right the first time. Either way you're gonna get a little NVH, but I'm not going to lose any driveability by going to a Truetrac and still gain crazy strength.
Who knows though, maybe I'll spool it waaaaaay down the road, but for now I'm happy......even though I haven't even installed yet.
#93
My TT 31 splines in the 9" has been holding good so far (Knock on wood). Mind you , the hawk only runs 11's with 26x11.5 ET streets.
I will definetly change it to a spool 35 splines in the very near future since the car is now dedicated to track use only.
#94
You don't need a stick to take one out. Mine has less than 2000 miles and is out. I'm waiting for the 31 spline wavetrac which they say is coming out this fall.
#95
Internet Mechanic
If you buy this diff, stay away from the track or make sure your making under 400 rwhp and its a automatic car and it should be fine, "Should" being the operative word.
#97
I hope they know. I am trying to get my car to run similar times as yours. When I saw the videos of your car coming off the line and shooting towards the parking lot, I decided to go with a spool. lol
#98
Yeah, unfortunately. I was just making sure the guy that posted above about there not being many instances of 35 spline TT's going out can add another one to the count. I'm about to head out in the garage and see what I can find.
#100
i forgot about this time too, i had to wash the mud off the side of the car, pull 2nd car makes a HARD right
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
keep the truecrap for the rock crawlers 4x4s.
http://www.streetfire.net/video/ls1-...ls1_691114.htm
in car of the roll
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
http://www.youtube.com/watch?v=VmePVXcJcKo
