Where to buy wire for bat relocation
Other then that, it's been working out fine. I ran a 0 ga wire from the ground to a stud we welded to the rollcage plate, that seems to have been enough to get a good solid ground. Then 0 ga to the push/pull switch, then 0 ga up to the firewall, ran a bulkhead connector thru the firewall, then 0 ga up to where the old battery was and tied all the factory wires together there.
I will be rewiring the car when it's apart, engine bay wiring will definitely all be going inside, as the car will have the nessassary stuff wired only.
https://ls1tech.com/forums/lsx-parts...use-block.html
Im an electrician, and used to be pretty big into car stereo. I really believe Stinger makes some of the best automotive wire. I use it on just about everything. You dont really need it, but it usually looks a little better, and stinger has a full line of terminals/distrobution acc so you can do a nice install.
More then strands when it comes to wire the Resistance is what is important. The higher the resistance in the wire the less voltage you will get. I could get into formulas, but you are going a short didstance, and running a wire that is overkill for its application. Some people will run a 2 gauge, so i would suggest getting what ever looks the best and fits the budget.
Chris
Ps if you want to look at stinger prices, i can pm you a link to a store, that is under msrp, and reputable. But they are a nonsponer. pm me if you want it.
