Drag Racing Tech
Sneak Peak (The Money Shot)
Old 11-11-2010, 10:25 AM
  #321
9sec93's Avatar
Originally Posted by waterproofer
would you post pic of your exhaust tips. love that. got to put them on my car.
https://ls1tech.com/forums/forced-in...bullhorns.html
Old 11-11-2010, 03:45 PM
  #322
waterproofer's Avatar
thanks, those are great!
Old 05-27-2011, 01:21 PM
  #323
fenton06's Avatar
I'll drag this bitch back up from the dead, how's everything going Tom?
Old 05-27-2011, 01:56 PM
  #324
Race your car!
JL ws-6's Avatar
I am very curious as to how the methanol is going as well. I know the car doesn't have a radiator setup in it anymore... cause that's sitting in my garage
Old 06-01-2011, 09:46 PM
  #325
Outlaw 10.5 Director
FSTR-THANU's Avatar
Just waiting on the new manifold, everything else is done and waiting!
Tom
Old 06-01-2011, 10:15 PM
  #326
Race your car!
JL ws-6's Avatar
Did you get away from the 4 bbl style for any particular reason? Take it to PM if you'd like....
Old 06-01-2011, 10:24 PM
  #327
FSTR-THANU's Avatar
When I switched to 16 injectors side by side, the runner wall was very weak. Cary was not comfortable with the thin section so we just switched up. Packaging and forced air distribution is much nicer as well!
Tom
btw: anybody looking for some turbo zoomies let me know. I have a couple sets to let go.
Tom
Old 06-01-2011, 11:47 PM
  #328
6techniques's Avatar
hmmm...turbo zoomies in a street car...
Old 07-22-2011, 10:16 PM
  #329
FSTR-THANU's Avatar
Fire in the hole!
Tom
Old 07-22-2011, 10:42 PM
  #330
Krazy98Z28's Avatar
How did she do on the alcohol?
Old 07-23-2011, 09:03 AM
  #331
Timmy P's Avatar
Looks Killer. Cant Wait
Old 07-23-2011, 05:55 PM
  #332
JRracing's Avatar
That setup looks awesome. Is this for a 275 radial class or something else?
Old 08-23-2011, 08:42 PM
  #333
SSPerformance's Avatar
any updates ??
Old 08-24-2011, 01:24 PM
  #334
FSTR-THANU's Avatar
Well, the switch to alcohol and high compression has definitely proven to make the power where and when I need it to run a competitive number in the ODR field! The engine dyno could not hold a full pull but we were able to see 1900ft lbs at 6000rpm with 24lbs of boost. My LSX block was the same block I ran last year when I hurt it in Florida with a devastating backfire; with that being said the block let go in a bad way on the first attempt at an 1/8mi pass. Naturally I had the block thoroughly checked prior to running it again and it was good but at this point who knows. From what I can tell it could not have been the horsepower that hurt the block but the massive tq coming in so fast and low. Soooo, my next steps are mainly surrounding what to do about the block. If I get a new LSX block fast enough I can get that in the car and continue testing the car while I study the long term fix which may be a solid cast LSX block, solid cast RHS block or DART billet block. Each route is under consideration at this point.
Aside from my block issues I did have an unrelated side issue with getting the FAST XFI to fire the 16 Moran injectors properly. The injectors tend to get really hot with the fast box after 30sec run time. This seems to cause the injectors to stick. I did a bench test with running the injectors using the XFI first and then the BS3 and the big stuff actually cooled the injectors off. This was NOT an issue running 8 injectors and when only 8 injectors are tested they do not heat up. It seems to only be an issue when using 8 Moran 500lb injectors in combination with 8 Moran 235lb injectors. I would assume the same incident would occur with the Precision 500lb injectors considering the BS3 has to make special changes to their driver unit for them but I do not know for certain since I did not test them.
As soon as I get a few more details sorted out I will post up the next plan and report what else I can break! LOL!!
Thanks!
Tom
Old 08-24-2011, 06:16 PM
  #335
7 Second Club
Phil99vette's Avatar
At this level there is going to be **** go wrong, its apart of the deal. Best of luck trying to get all the pieces to work together.
Old 08-25-2011, 09:43 PM
  #336
FSTR-THANU's Avatar
I hear ya Phil! I knew it was not going to last long but hell! I was hoping to get a couple races anyways, when your doing things never done before this stuff is bound to happen. Unfortunately for me my budget was supposed to be for a racepak and some new electronics this winter but... I should not be down long!
Tom
Old 08-28-2011, 01:37 AM
  #337
mike06tork's Avatar
Tom[/QUOTE]
nice ride.. but i may ask, whats the deal with that truck on the back...??? what the set-up and plans?
Old 08-28-2011, 09:59 AM
  #338
FSTR-THANU's Avatar
Originally Posted by mike06tork
Tom
nice ride.. but i may ask, whats the deal with that truck on the back...??? what the set-up and plans?[/QUOTE]
Thank you. The truck is an all motor 14.5:1 kinsler injected 6.0 with C5R heads backed up with a Chance 2pc converter and a Rossler th400. Basically built with a bunch of left over stuff from prior builds. It is run by a FAST XFI. Should be a fun truck to play around; it is not built for any specific class racing in mind.
Tom
Old 08-28-2011, 05:08 PM
  #339
Reject's Avatar
*fap fap fap*
Old 08-28-2011, 11:49 PM
  #340
mike06tork's Avatar
Tom[/QUOTE]
damm sound good.. that truck i would like to see what times it put down. has it been driven already? thanks for the reply
Quick Reply: Sneak Peak (The Money Shot)
