Drag Racing Tech
Sneak Peak (The Money Shot)
Old 04-30-2010, 08:32 AM
  #161
Outlaw 10.5 Director
FSTR-THANU's Avatar
EDIT: How many gallons does your dry sump tank hold? Is there a science to this or is it based on size constraints of the tank?
I worked the tank size out with Bill Dailey from Dailey Engineering but there is really no rocket science involved. My tank holds exactly 1.5 gallons. I completely drain the oil and replace the filter EVERY race. We are not doing any roundy round stuff here so 3 gallon tanks like the one I used last year are just excess mass for me. I looked at tanks in capacities from 1 to 5.5 gal. It's purpose is to serve simply as the primary oil reservoir. The tank receives the oil scavenged from the outlet ports of the dry sump pump, the oil enters the tank’s inlet fitting, the oil hits an internal “strainer” that directs the oil in a stream, the oil falls into the reservoir to be pumped back through the engine. Potentially some small reduction in oil temps might be achieved with increased volume but the minimal run time I see it is not really necessary.
I assume there is a drain hidden somewhere on that monstrosity of a ic/tb/h20tank....
Absolutely!
Tom
Old 05-02-2010, 07:17 PM
  #162
FSTR-THANU's Avatar
A little converter pic. We don't like to use Chance converters or anything...
Alum/Titanium
Joe from Hyperaktive Solutions hooked me up with some cool electronic goodies! Much more to come
Chute handle is mounted
Kill switch is in
XFI Mount
Steering needed to be changed to make more header clearance
Some sheet metal work
K-member attachment to the chassis
Tom
Old 05-02-2010, 08:59 PM
  #163
airfix's Avatar
This car is amazing!
Old 05-03-2010, 12:10 AM
  #164
03supercobra's Avatar
Beautiful! Everything done to perfection!
Old 05-03-2010, 01:41 AM
  #165
XpEdItIoUs's Avatar
Put that car in a car museum when it done. It's too beautiful to race.
Old 05-03-2010, 05:35 PM
  #166
y2khawk's Avatar
at least my doors will go fast now
Old 05-03-2010, 06:53 PM
  #167
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ What was wrong with the original white doors? I noticed your passenger side door missing after a couple pictures. Is your car ever going to run again? I keep seeing it in all of the background of the Stenod builds and it looks like it is slowly and slowly losing pieces every time I see it. I'm guessing it's kind of like my 93. It may run at some point, but it is so far from ever going back together right now that I don't even both with it.
In regards to the converter how much weight does the aluminum / titanium assembly save?
Old 05-03-2010, 09:34 PM
  #168
5.3LJimmy's Avatar
A solid 10lbs from your wallet for sure.
Old 05-03-2010, 10:58 PM
  #169
FSTR-THANU's Avatar
I still have the white doors and they are perfectly good but all the hardware like cranks and windows and handles are sitting in a box and Harlan's were ready to go. Not that it is very difficult to put the doors together, it's just our way of keeping the original turbo LS Firehawk alive! And yes, there will be Harlan shift light in front of me too. Some things you just don't mess with.
The converter is about 5-6lbs lighter. I told Marty I was happy with our last set up but he was not having it so next thing I know...
Tom
Old 05-04-2010, 09:23 AM
  #170
y2khawk's Avatar
Maybe eventually. But I wasn't using the stock doors anyway, carbon So it saves me from having to sell and ship them
I just have to find a place to put the car, since I now live 2 1/2 hours away from it
Old 05-05-2010, 11:15 AM
  #171
427
427's Avatar
Car looks killer guys, keep up the good work!
Kurt
Old 05-17-2010, 10:37 PM
  #172
White.Lightning's Avatar
Any updates?
Old 05-20-2010, 11:05 AM
  #173
FSTR-THANU's Avatar
Originally Posted by White.Lightning
Any updates?
Just taking a little break to re-coup some cash flow. I'll be back at it very shortly.
Thanks,
Tom
Old 05-20-2010, 03:13 PM
  #174
tektrans's Avatar
Yeah that's my strategy too.
They don't call it "The MONEY Shot" for nuthin'..
Old 05-20-2010, 03:59 PM
  #175
FSTR-THANU's Avatar
That is definitely and understatement!
Tom
Old 07-07-2010, 07:36 PM
  #176
FSTR-THANU's Avatar
It's been a little so here are a few new pics. Not bad for being painted in a garage:
Tom
Old 07-07-2010, 07:41 PM
  #177
SSPerformance's Avatar
man killer built
  #178
man killer build
Old 07-07-2010, 07:49 PM
  #179
FSTR-THANU's Avatar
Bill from QC Coatings has done it again! I have used Bill exclusively for like 8 years now and he has never once let me down.
Thanks Bill!!
This is Paint:
And this is QC Coatings:
Tom
Old 07-07-2010, 08:06 PM
  #180
Broke EF's Avatar
Holly **** does that look good!!! I cant wait to see it finished.
Sean
Quick Reply: Sneak Peak (The Money Shot)
