Wolfe through-floor subframe connectors-Are they needed?
The car is going to be completely gutted and lightweight everything. My goal is to be between 2700 and 2750 lbs without me in it and get it to run a 9.80 or quicker once I get it all dialed in.
I just ordered the cage, an SOS 10 pt chromoly that will cert to an 8.50. My question is, to those of you with the Wolfe through floor subframe connectors, are they really needed and helpfull? They seem awful heavy and before I order them I just want to be sure that I need them.I am building this car to handle quicker ETs than I am running to prepare for the future.
Im installing everything myself including the cage and subframe connectors if I end up buying them.
Thanks!
Now if you don't see yourself going faster then 8.50, the wolfe subframes are not a bad idea, or even just the round weld in bmr ones. Stick the 10 point in there and be good to go.
Im also considering mini tubing the car while I have it apart.
Josh said its truck frieght and will usually take a couple weeks. Which I dont think is bad at all. Thats why im really trying to decide on teh SFCs. I have to get them in before the cage. Im also a bit worried that the cage wont line up with the SFCs.
