Drag Racing Tech
Formulas with 28x10.5 tires pics please
Old 03-29-2010, 02:03 PM
AChotrod's Avatar
lol^ Its a stock headed lt1, therefore its impossible to be a race car. Did you have to cut off the bump stops or BFG the wheel well with the 8" rim?
Old 03-29-2010, 03:07 PM
kline454's Avatar
removed bump stops, left the brackets for the bump stops,rolled the fender lip, btw im still a stock headed lt1 also...
Old 03-29-2010, 03:37 PM
98blueSScamaro's Avatar
Ac You got a lane with me on and off the gun!!!! And i was i runing a 28x10.5x15 with my m6 and all i have to say is hammer and sawzall. cuz you are m6 we mph more so we get alot of tire growth and with your car being a m6 make sure you get a stiff side wall or you will be using the whole lane with a 3200lbs car. just a heads up.
Rob
Old 03-29-2010, 03:46 PM
AChotrod's Avatar
I run a DOT bias ply tire to meet the LTXshootout rules.
Kline I hope with the 8" rims thats all Ill need to do. Did rolling the fender mess up you paint?
Old 03-29-2010, 04:47 PM
kline454's Avatar
the paint on the lip its self cracked but nothing that you will see with the tires on, but if your not carefull you can put waves in the quarter panel.
Old 03-29-2010, 04:57 PM
kline454's Avatar
Rob
Ill try you on the gun...Ill be @ 41/NLR a few times this year,
Old 03-29-2010, 05:14 PM
AChotrod's Avatar
Did you use a fender roller or just bend it to shape? I hate to ruin the factory paint.
Old 03-29-2010, 07:06 PM
kline454's Avatar
just bent it to shape. fender roller would work alot better.
Old 03-29-2010, 07:43 PM
AChotrod's Avatar
Ill see if I can track one down or have a body shop do it then. Badhawk had them on his firehawk and just said he needed the BFH mod. I hope Im so lucky.
Old 03-30-2010, 10:15 AM
AChotrod's Avatar
I got them on last night and there is at least 3/4" or more all around the tire and plenty of space behind the tires.
I tried 3 different spring combos also. I tried stock with heater hose(too high), Hotchkis 1" drop with heater hose mod(too low), and ended up with the 1" drop springs and put the insulators back in(just right).
Old 03-30-2010, 11:08 AM
ATVracr's Avatar
Old 03-30-2010, 11:11 AM
  #32
AChotrod's Avatar
That looks good! Is the rear narrowed?
Old 03-30-2010, 11:29 AM
  #33
ATVracr's Avatar
Ya....-3" on each side I think.
Old 03-30-2010, 11:33 AM
  #34
AChotrod's Avatar
Heres how they fit. I still need to center the rear a bit, but still not sure im happy with how far they stick out compaired to my 27x10.5s. Damn I wish they made a 28x10.5 DOT bias ply tire.
Old 03-30-2010, 11:44 AM
  #35
ATVracr's Avatar
Radials are faster.
You need to lower that thing a little.
Old 03-30-2010, 12:15 PM
  #36
AChotrod's Avatar
Radials dont work on my car very well since its a M6. I can pull the rear insulators and drop it some more but was kinda worried about the fender lip hitting the tire. It takes about 50% of the pictured gap away. Fronts are strange DA coil overs so I can set them at what ever I want. Ground and trailer clearance also worries me dropping it so low.
Old 03-30-2010, 01:58 PM
  #37
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,159 Likes on 753 Posts
What wheels in back ach, GWelds or Racestars or something?
Old 03-30-2010, 02:52 PM
  #38
AChotrod's Avatar
They are Racestars with GW center caps to match the front.
Old 03-30-2010, 05:47 PM
  #39
DopdBrd's Avatar
Could you get me a shot from the rear Mikie? I'm looking at running those tires on a 15x8.
I'm lowered pretty good and can get on and off the trailer just fine, but the trailer is a low pro trailer with a 2 ft dovetail.
Old 03-30-2010, 05:53 PM
  #40
AChotrod's Avatar
Ill get ya some as soon as I can pull the car out for pics in the day. Too hard and close for anything in the garage.
Quick Reply: Formulas with 28x10.5 tires pics please
