Drag Racing Tech
Final stage of my stock internal M6 build
Old 05-09-2011, 09:46 AM
  #101
NSSANE02's Avatar
Originally Posted by JRracing
blow the car off real good and clean with a solvent cleaner like prep solve or wax and grease remover.
That won't affect the primer?
Old 05-14-2011, 11:54 AM
  #102
Chris Gage's Avatar
Nice build, cant wait to see how it does. I am planning for a SI build currently, I just cant decide whether I want to run a m6 or a th350. With the amount of "in depth" work you're doing, I would def. run the 4.56 gear with a 29 tire.
Old 05-14-2011, 05:37 PM
  #103
brandoz28's Avatar
the wax and grease remover is made for cleaning that stuff up before you paint it, you'll be fine
Old 05-14-2011, 09:07 PM
  #104
NSSANE02's Avatar
Cool, thanks
Old 05-26-2011, 04:42 PM
  #105
djfury05's Avatar
in post #76 regarding your intake setup.. how is this going to work? Is it going to go over the top of the radiator or behind or what?
Old 05-26-2011, 06:07 PM
  #106
NSSANE02's Avatar
Like this
Old 05-26-2011, 06:30 PM
  #107
djfury05's Avatar
very nice.. how much further back does the radiator sit now with it like that? You going to put some sort of heat shield to keep IAT's down?
Old 05-26-2011, 07:23 PM
  #108
chrs1313's Avatar
^^where did you get that bend at, is it alumin or steel...
do you happen to know the centerline radius of the bend, looks fairly tight...
I removes my lower radiator support and fabbed up some alumin brackets so I could move my radiator back some and down 3-4"...plently of clearance now and saved 16lbs off the nose
Old 05-27-2011, 09:11 AM
  #109
NSSANE02's Avatar
The radiator position is pretty close to stock, maybe 1" further back at most. No heat shield, not really worried about heat with the intake being 4" and fairly short.
I got it at globaltecheng.com it's aluminum with a 60 deg bend. I dont remember the radius though.
Old 05-27-2011, 09:18 AM
  #110
5w20's Avatar
nice, i know someone who needs something like that
Old 05-27-2011, 11:13 AM
  #111
chrs1313's Avatar
ha yeah that is exactly where i was going to get mine to test out...I am sure it is the tightest radius they have for 4" aluminum which is a CLR of 6"
thanks
Old 05-27-2011, 12:44 PM
  #112
NSSANE02's Avatar
thanks
Yup, 6" sounds right.
Old 06-18-2011, 05:44 PM
  #113
NSSANE02's Avatar
Finally got the damn engine bay painted! I'm kinda dissapointed because I got a ton of debris in it when I went to do the clear coat but it's done now so **** it. Still need to do some wet sanding and buffing but it doesn't look too bad.
Old 06-18-2011, 06:14 PM
  #114
wg871's Avatar
Nice! Keep us updated
Old 08-04-2011, 03:39 AM
  #115
djfury05's Avatar
update?
Old 08-08-2011, 11:30 PM
  #116
NSSANE02's Avatar
Nope. I just got home from a 6 week job 5 days ago and I'm already back out on another ~3 week job.
Old 09-05-2011, 09:28 PM
  #117
ds98formula's Avatar
subscribed
Old 09-15-2011, 01:10 AM
  #118
NSSANE02's Avatar
Little update. The motor is back in, fuel system is done, and most of the harnesses are back in. I don't have any good pics but here's a couple of how I ran the fuel lines.
Old 10-07-2011, 01:19 AM
  #119
stephen4036's Avatar
your **** is so clean man
Old 10-07-2011, 08:39 AM
  #120
Duffster's Avatar
Because it hasn't seen daylight since April 2010. . .
Quick Reply: Final stage of my stock internal M6 build
