The Turbo Ta Build Thread
The car does have a 2 step, and we will be getting that set up the next time we are at the track.
Thanks for your help phil! We both greatly appreciate your help.
Thanks, Chris
Also looking at the video, I think we need to make some adjustments on the sway bar. So we know we have some work to do still. Today was a great day, and we made some good progress. Unfortunately we had to cut it short when I had a bit of an accident. I should be good to go by next weekend, and we can get back to work!!
Lastly, I want to say that the addition of the chute is probably one of the best things we ever put on the car. Obviously it helps to slow the car down quite a bit, but the braking is so much more comfortable with it. The end of the run is no longer a worry about slowing down, or making the turn off. We are only in the 140's, but I will pull it EVERY pass because of how much better the car slows down with it. Packing is quick as well, so there really is no downside. I mention all of this because you see a lot of people saying things about how they are a pain in the ***, or not needed until XXX MPH and so on. If you are in the 140's, there is no reason not to have one, and not to use it every pass.
Sean
As long as it takes to get the boost to flatline.... Launch RPM was over 4K, and we had a problem with the two step so we still were not using it. But more or less I would watch the boost until it was stable for a second and then go. As Chris said we started with the manifold pressure at 5, went up 1 for the second pass (which was a throw away because of me, but it hooked), and then up another .5 on the last pass (9.50 pass). So the launch boost was right around 7psi, and still dead hooking, but it didn't seem to come into the power quick enough when I came off the brake.What is the 1st stage of the AMS set to? Not to be a broken record but without logs we're pissing up a rope.
I would get the car on a set of scales and make your adjustments from there. Try to tune the front shocks to get the back right and set the sway bar neutral.So we know we have some work to do still. Today was a great day, and we made some good progress. Unfortunately we had to cut it short when I had a bit of an accident. I should be good to go by next weekend, and we can get back to work!!
Sean
I looked at the AMS settings, and I cant remember what they were off the top of my head. I will go back and get that for you tomorrow.
We are trying to sort out the problems with the data logging. We want to be able to use the HP Tuners to data log for us since we have the cable already, but its not so plug and play. Changing to EFI Live is an option (that is what the car is tuned on), but it is a decent chunk of change that we would rather see go to a true stand alone.
We do understand the importance of data, and we are working on getting more and more so that we can maximize the whole set up. We will get the car on some scales in the next few weeks and get that all dialed in as well.
Again, thanks for the help and advice it is greatly appreciated.
Sean
Sean
Sean
a bit overly-excited, eh? lol
I got the safety out of the chute before he launched.
Thanks, Chris
That is the Byron Nuclear plant in the background pumping out some clouds
Sean
http://www.lsxtv.com/features/car-re...bodies-part-2/
Sean
So we loaded up, and took it home. I think we pulled the trans the following weekend, but I cant remember. Eventually we decided to rebuild it ourselves. So sometime in there Chris ordered up new clutches and steels, when they came in we had at it. We tore down the trans, and found what happened. When we (I) put the deep pan on, there is a stud that goes into the valve body to hold the end of the filter level. Well apparently that backed itself out which let the trans filter fall down and pull in some air. That of course let the trans go dry, and burned up the clutches. It also burned up the rear case bushing, which we did not get the first time around. So we tried to take it apart and put it together the same day, but after checking the clearance in the case bushing it needed to be replaced badly. So we ordered one up, and waited for it to come in. Then when it came it we tried to put it back together again and things were just not lining up. Turns out that we had an upgraded rear thrust bearing that didn't work with that style case bushing! So we had to order more parts again, but we got it right that time.
So we put it all back together, somewhere in there we had the converter gone through and re-stalled. We also changed the rear gear since we had topped it out already. We finally got it all back together, and ready to go a couple of weekends ago. We have driven it around, and the trans feels even better than before. The shifts are nice and firm, much more than before. The trans brake works perfect, and the car is running great after a set of plugs.
Unfortunately, we have not had a chance to get it back to the track yet. We probably wont be able to get to the track until mid/late October! We are both really busy with all kinds of stuff, but me getting married is probably the biggest hold up right now. I am moving next week, and getting married October 7th, which means all of the weekend between now and then are busy with something. We will be back out at least once more this year!
Sean
We do go to GLD, but we haven't in a while. I was at the last RSD, and I have to say I am disappointed in that track these days. BUT we do want to try and make it out there if we can. It would probably have to be a Thursday night (slicks only), but with work that doesn't look very likely.
We should have some kind of an update before winter hits
Sean
