The Turbo Ta Build Thread
Thanks, Chris
I got the proflow intake, and also got the proflo Throttle body. The throttle body came with bolts, and a new gasket, so i used those. Its definatly going to be a sae thread, cause its edlebrock.
The Directions that came with the intake tell you the size, and length of the bolts to get. They call for a m6x1x50mm length. I got some from mcmaster car that were allen head, and used a m6 washer. IF you have never bought from mcmastercarr google them, and you will love them.
Let me know if you have anymore questions about the fuel setup. IF you go through the thread im sure i have pictures of all of it.
On a side note, i have a really nice Fuel lab pressure regulator, because i wasn't going to used a boost referenced one at first. I put it on the car, and never used. I have the regualtor which was around 130 bucks, and all the npt fittings to adapt to 3 -6's out of the regualtor. Probably 30 bucks in an fittings. I will give you the regulator for 100 shipped if you want it. Its just sitting on my bench in the garage.(i can get you pictures if you like) As far as a gauge goes, the FPR has a gauge port on it. You can get the cheapy speed inc marshall fuel pressure gauge that will spin right in. This gauge does not have to be super accurate. Just get you in a ballpark, and then the car is tuned for that fuel pressure.
Let me know if you need anything else.
Thanks, Chris
Thanks, Chris
but this car definetly shows his great work. This is the most solid mount i have ever seen out there, and is all very nice quality and lightweight stuff.
If anyone needs to see it from any other angles dont hesitate to ask.
Thanks, Chris
The power master is rated @ 100amps, which should be fine for a street car, as long as you dont have a crazy stereo or anything.
The one on my car is rated for 70 amps as sean said.
Thanks, Chris
Would this work?
http://www.summitracing.com/parts/SUM-220648B/
Would this work?
Sean
