The Turbo Ta Build Thread
When we got to Troy's I left the camera in the truck, so I didn't get any detail shots of the car. After Chris shoveled off the trailer, and I torched out he D-rings, we got it loaded up without much incident. I will say the snow does certainly help for moving the car around with a spool
Here is a couple of pics of Chris tying down the back, and the car all loaded up.
And the only pic of any of the detail of the cage (for now)
The cage looked awesome, and we were both very happy with how it all came out. There is still a little work to be done, but everything looks great! While I was snapping pics, Chris realized that we were behind schedule by a good amount. So we had to quickly wrap everything up, and haul *** back. You will notice that we had both safety pins in the chute but not the cable. Well, we either should have had the cable in (which I looked at, and decided there was no need), or taken out the one that holds back the launcher so there was tension on the pack. Since we did neither of those, the pin holding the pack fell out (also note it was flag down), and the chute came out on the highway! It was not very dramatic since we strap the car down tight, but it sure was funny as hell! I wish I would have gotten a pic, but Chris pulled it over quickly, and we just tossed it in the back of the car and kept going.
Then it was just a matter of trying to back the whole deal up the driveway, get the car unloaded, and put away in the freezing cold so Chris could get home in time. Nothing too exciting there, just cold.
Now that its back, next weekend we are going to more or less just go over everything and get a game plan together. There are a few other things we decided to change, but more on that later. We were able to check the motor plate template that Bob at AEI had sent up for the new motor. Everything seemed to line up just fine, but we did not get a chance to run bolts in to be 100% sure so we will do that next weekend as well. The following weekend we should really start to get cranking on everything. We have a little bit of fab work on the front end, then its pretty much reassembly after that. Stay tuned, and thanks for following along!
Sean
Sean
The car went a best of 9.44 @ 148 with a 1.5 60' time
If you pay close attention you can tell there is a big delay before the boost comes in. We found after the trans was broke that there was a .5 second delay on the AMS from launch to stage 1. So we were trying all kinds of things and the 60' would not get any better, that was why. We were also on the limiter at the stripe. We should annihilate that time this year first pass
Sean
We couldn't find the blow off valve at first, we found it later but I was too lazy to re-shoot anything.
Also, we need a new clamp for the exit side of the wastegate, so the dump tube wasn't installed either.
And here are a couple pics of the inside of the car which is trashed right now.
This last pic wont look like much, but we did a lot of cleaning of this area (and the rest of the garage really).
That's all for now, not very exciting I know. We did spend a lot of time cleaning everything up, and putting all of the tools away so we were good and organized for the upcoming weeks. Chris also got some of the material and parts ordered up that we will need. The plan next weekend is to start on the mini tubs as well as start cleaning up the wiring and the inside of the car. After that will come redoing the structure for the front bumper and the front of the hood. Then its just a matter of putting it all together, just that easy
As always thanks for following along!Sean
