The Turbo Ta Build Thread
I almost forgot (OK I did forget) to add the pics of the turbo kit back from coating! We only kept one pipe untouched, so this is pretty much the entire turbo kit. Again we have to give a big shout out to Q.C. Coatings in Utica MI. Bill is the man, and as always has gotten us exactly what we wanted in amazing time! If you need anything coated (ceramic or powder) be sure to give them a shot, they will not disappoint! I will get some better pics soon showing off how great everything looks, but for now here are some cell phone shots.
OK, NOW we are fully up to speed! I should have another update in a couple of weeks, and hopefully that has some shots of the motor going together as well.
Sean
I think right now we are hoping that the block is machined and shipped in ~2 weeks (just a guess), and the motor can be together by the end of July or early August. Then we can get it all put back together, tuned, and track ready in another weekend or two. So probably mid to late August before we hit the track.
Sean
That is all for now. It came in this afternoon so all we got accomplished was setting it on the stand and staring at it. They will be taking measurements and starting on machining soon. I am going to try and get as many shots of the process as possible, and will keep the thread up to date. Now that the block is here things should start moving pretty quick!
Sean
The Callies Dragon Slayer crank
Callies Ultra H beam rods
And lastly the PRC heads
There is a little work to be done to the heads still, then it can finally all get assembled. The next project will be moving the car and all the tools to Chris's house though. That should be a fun filled weekend of work...
Sean
"The New Dart LS Next Engine Blocks are designed to eliminate the high RPM power loss and the problem of separate bays in the crankcase associated with the ''Y-Block'' design of the LS engine series. This has been accomplished by using the conventional style small and big block Chevy 4-bolt steel main caps with 7/16" bolts, full main webbing and crank barrel around a standard LS rotating assembly for maximum bottom end strength!"
Next weekend we will probably mock the turbo kit up on the motor on the stand just because. We are also supposed to be picking the car up next Saturday, so I should have some pics of that up as well. That is all for now. Once we get the car back though the updates should be pretty steady.
Sean
Sean
I don't have the part number, but i can ask the engine builder. Thanks, Chris
