Drag Racing Tech
The Turbo Ta Build Thread
Old Mar 6, 2011 | 09:42 PM
  #201
fuel's Avatar
its looking real good..........
did you use your stock fans on the griffin radiator.
Old Mar 6, 2011 | 09:56 PM
  #202
Sideways240sx's Avatar
Originally Posted by Taubr Unit
that Kurt Urban vapor vent thing is pretty cool. How much was it and where does the 5th port go? Just releases into the air or?.......
The kurt urban water vapor system is 200 bucks. It includes the 4 lines, and the block with fittings. The 5th line goes to the top part of the radiator. I have a 1/8 npt bung just underneath the fill cap. So the steam can leave the heads, and return to the radiator, and turn back to liquid i guess... More or less the same as it was stock, just a better flowing sytsm, and should help alot with heads lifting. Lots of people swear by them.
Look on his website, he has them listed
Chris
Old Mar 6, 2011 | 09:58 PM
  #203
Nope, two cheap summit 10" electric fans. I believe they were pro form and about 50 bucks a piece. I also have a 3rd one on my trans cooler. I wouldn't drive it stop and go rush hour with it, but for highway, or normal crusing they used to keep the car pretty cool when i had it on the street.
thanks, Chris
Old Mar 7, 2011 | 05:23 AM
  #204
Broke EF's Avatar
Jerry,
In the last pic you can see the line going to the radiator just above the catch can. We used a 45 degre fitting on the block to go up over the valve cover and then just routed it to the radiator. It was a little bit of a pain in the *** getting the line through the runners on the intake because the intake is so tall, but we got it done.
Sean
Old Mar 7, 2011 | 03:00 PM
  #205
studderin's Avatar
baller
Old Mar 7, 2011 | 05:08 PM
  #206
6techniques's Avatar
hey what vacuum block is that you used?
Old Mar 7, 2011 | 06:11 PM
  #207
Broke EF's Avatar
Thanks guys. It's just an aluminum one from McMaster Carr. Chris may know the part number, but I am sure you can search for it easy enough.
Sean
Old Mar 9, 2011 | 12:21 AM
  #208
TurboZ28408's Avatar
i noticed your oil pressure in your " trip around the block" video in your youtube. stays steady at 50 psi and seems to drop a lil bit ?
Old Mar 9, 2011 | 05:23 AM
  #209
Broke EF's Avatar
Im not sure what video you are talking about. The only one that shows the oil gauge you can see it a little under 50psi untill Chris hits the gas then it goes up to around 50psi, then when the RPM drop again it goes back to a little under 50psi. We have not seen any issues with the oil pressure that I know of, and I know we kept a close eye on it when it was on the dyno.
Sean
Old Mar 11, 2011 | 12:23 AM
  #210
slowblackbird's Avatar
i love the dzus fasteners on the front bumper, i wonder how that would hold up on a street car
Old Mar 12, 2011 | 10:18 AM
  #211
Sean
but it hits 50psi max and doesn't raise right ?
reason i ask is because my car idles with 20 psi and once i get on it it hits 40 psi and stays there. gets me a little nervous because it should be more so aroudn 60-80 at wot right ?
Old Mar 12, 2011 | 11:15 AM
  #212
I could be wrong but i have never seen the oil pressure get that high on my car.
When i had the stock oil pump mine probably idled are 25, and higher in the rpm's in the 40's. Now i have the meiling hi flow oil pump, so i have higher pressure.
Thanks, Chris
Old Mar 14, 2011 | 06:57 PM
  #213
Broke EF's Avatar
Well another weekend of work has come and gone! It is getting very close now, and we are dying to wrap it up and make some passes!! Anyway, we are not racing yet of course but we did wrap up a bunch of smaller projects. Friday night I got started on mounting the alternator. We were doing some testing for AEI CNC who makes all kinds of pieces for various applications. They have been working on an alternator mount for LS motors with truck manifold turbo kits. I believe that he has only tried this kit on a car that had V-Bands welded to the manifolds, which we do not (yet). So the first kit he sent out didn't work for us even though the brackets fit absolutely perfect. So we got on the phone with Bob and started brainstorming a solution and came up with two. He had them cut, machined, and on the way to us Monday so we could try them this weekend. Here is a quick shot of all three kits laid out (with the exception of the stainless steel bracket for the original kit).
The very bottom set is the original which holds the alternator tight to the block and catches the 4 rib portion of the crank pulley. It would work great if you have a v-banded truck manifold. The top set moves the alternator straight down from the original location and clears everything for us, but is a little tight. The middle one was just right! It moves the alternator down some, and forward to catch the 6 rib portion of the crank pulley. Keep in mind that he made the other two kits with nothing more than a phone call and a couple of pictures. He does not have a LS in the shop to try these on before he sent them to us, and they all fit like OEM pieces.
Here are some pics of the one we left in the car.
Unfortunately I cant be trusted, and I broke the alternator! We tried to clock it so that the plug was further from the manifold, but I separated it and it all came apart. So we did have a chance to throw a belt on and tension it to make sure it was all good, but I never got any pics of that. Chris ordered up a new alternator and I will have finished pics next weekend.
Chris got crackin' on the fuel pumps. I'm sure you all remember that we had minor fuel issues that showed up while we were on the dyno (luckily). We weren't really sure what the problem was, just that we were lower on pressure than we should have been. Well as soon as we got the pumps out of the car the problem was obvious, one of the rubber hoses from the pump to the "Y" block had a 1" long split down it. So we replaced both lines with some AN, and while they were out beefed up the wiring. Chris ran a new 12ga power and ground from each pump out of the tank. Both pumps are now fed by their own independent 10ga power wire (10ga back to the their own relays, then 12ga from the relays to the pump), and they both have beefed up grounds. Now we can test each pump independently of one another, and they are both working to the best of their ability's.
Saturday Chris got to work installing the new bigger battery, final installing the battery box, and the last of the battery wiring. He didn't however finish cleaning up the back when he was done, so I have no pics I whipped up a mount for the new passenger seat. I more or less copied the mount the Eric at Midwest Chassis had made for the driver seat out of some aluminum angle. The problem however is that the passenger side that the famous bump where the front of the seat mounts. So I had to raise the rear of the brackets up to make the seat sit properly. I didn't get pics of the whole set up because I forgot, but we need to take it out to paint it so I will get some next weekend. In the meantime I am happy with my aluminum welding so far, so I DO have pics of that!!
And a couple quick shots of the seat in the car.
Then we threw the drive shaft in, set it on the ground, and drove it outside so we could clean up a little. Here is the video of it moving for the first time this year!
http://www.youtube.com/watch?v=VBNhgFKaYzE
And since I didn't feel like sweeping, I pretended like I was taking pictures of the car
Yes the car is dirty as hell, but at least its in the sun. The tail lights are off because we just had the bumper off, and it needs to come off again soon so why bother. And the cord is for the battery charger since for some odd reason we still don't have an alternator
Anyway thats all for this weekend, now we just have to wait for a couple things to be all finished up. We should be 100% and on the dyno with in a few weeks I hope, then its off to the track to run 12's Thanks for following along!
Sean
Old Mar 14, 2011 | 07:07 PM
  #214
AChotrod's Avatar
Looks awesome! I need land!
Old Mar 14, 2011 | 07:15 PM
  #215
Broke EF's Avatar
Ill start the bidding at 3'
Sean
Old Mar 18, 2011 | 09:23 PM
  #216
http://www.youtube.com/watch?v=q8xOQpEMzWQ
Old Mar 18, 2011 | 09:27 PM
  #217
fuel's Avatar
its not working.......
Old Mar 18, 2011 | 09:33 PM
  #218
now it is.. I posted before they finished. Sorry
Chris
Old Mar 19, 2011 | 09:28 AM
  #219
9sec93's Avatar
BAD ***!!!! i love the little fabricated parts. the alternator bracket is sweet too. i would love to move my alternator down low. only problem is my crossover pipe turns towards that way from the passenger manifold. anyway, very nice build. seems to spool pretty fast. i think i need some land.
oh yeah, why didnt you use 1/4" plastic line with the pushlock fittings like used for airbrakes on trucks?
Old Mar 19, 2011 | 09:34 AM
  #220
9sec93's Avatar
what balancer is that?
