hookin up ls1 harness to v6 interior wiring??? help
im doing a v6 swap.. can you hook up the ls1 harness to the interior v6 wiring? talking about using the stock v6 gauges n fuel pump. wondering if i can plug the harness to the inlets under the heater box. need some info on this.. thanks??
yeah its a 98 v6 rs. how can i make this work?? i have a wrecked 2000 z28 that the motor is goin in the v6. i have every this.. what am i gonna need to get the engine strated in the rs?? fuel? gauges? the pcm is flashed too.
Jose
Jose
sounds like alot of work.. the car is gonna be a track car.. what can i do for fuel?? do i have to swap out tanks? or can i just up grade fuel pump? what knid of fuel cells are out there? i dont like nastys performace cell.. any others?
get a stand alone harness and wire your **** up im doing the same thing you are doing but mine is a street car and a 99 it is alot easyer then most people make it out to be also
my bigest issue is get fuel to the motor. heard of guys doing a race harness.. i need more info. also you know were to get a wiring diagram of the whole car? i got power windows n want to make sure theyll work.
I'm in the middle of my swap. Going 99 V6 to 99 LS1. We are using the V6 body harness and the LS1 engine harness. So far so good, with the key in the ignition, everything lights up, chimes, and the fuel pump primes.
I dont know about the swap stuff. But sence you have a 98, maybe look into getting a body harness for a 98 LS1 car. Its a bunch of work behind the dash, but if your doing free weightsavings your have it out anyway.
The engine hanress are $$ but the body and front compartment you can get for $30-45 each full good stock harness. There not a lot of guys looking for thouse harness, so there cheap foprm the guys that part out LS1 cars. i'm getting a extra to remove all the unused wires on my car, afetr I found out I can get them so cheap.
@studderin yeah you know what section i might find the harness.. im going for a cam only record here california. i lookin for a wiring diagram to cut off all da extra wiring not needed. how did you do your abs delete? car is just a shell at the moment.
I made the front brake line myself, off the stock master with adaptor fitting. Still have stock front brakes, and the power assest.
https://ls1tech.com/forums/drag-raci...itch-diet.html
