Drag Racing Tech
Suspension
Old May 18, 2010 | 07:38 PM
DIRTY_WS6's Avatar
Post Suspension
Ive heard that installing V6 rear springs on a trans am will give a better launch due to a better weight transfer? any opinions on this?
Old May 19, 2010 | 11:17 PM
conde'strans's Avatar
Many choose this route because they perform great for weight transfer and are a cheaper method for improvement instead of buying high dollar aftermarket ones. So to answer you, YES they have proven to perform real good.
Old May 19, 2010 | 11:20 PM
SuperSlow02's Avatar
Every other time this has been brought up concerning a 4th Gen...the rear springs are the same in a V8 and V6 car...
edit, did a quick search, you would have to get them off of a 93-97 Fbody
93-97=95.4
98-02=114
Old May 20, 2010 | 12:00 AM
camscam02's Avatar
you want it stiff in the rear, you are wasting momentum with the car squatting on soft springs.
Old May 20, 2010 | 12:23 AM
My thoughts exactly...didnt want to start a pissing match. as to so and so said to do it like this.
"loose" in the front, "stiff" in the rear. But you also want the rebound in the front stiff so you dont unload the rear.
Old May 20, 2010 | 02:43 AM
camscam02's Avatar
Every suspension setup is different per car. In the end you want as much forward momentum rather then up and squat down momentum, basically like leap frogging the car off the starting line. We run the front as tight as possible without it spinning or slowing down in the sixty foot and real stiff compression wise on the rear.
Many people may have other opinions but just what we do and seems to work so far.
Old May 22, 2010 | 10:27 AM
armyboyatc's Avatar
Having a stiff suspension is great for a lightweight car with little to no traction problems but in a full wieght car you need a little bit softer rear suspension to get the traction. I agree you lose time by first squatting and then taking off but its between spinning and squatting then I will take the squat every time.
Old May 22, 2010 | 05:23 PM
02 BLK WS6's Avatar
This /thread.
A little anti-squat will push the back tires into the pavement creating more traction. Squat does the opposite. Heavy cars need the front settings looser than a light car. Heavy cars need quicker weight transfer/more weight pushing the rear tires into the pavement for traction.
**edit**
You can run a softer rear spring and set the suspension up for anti squat and still get decent traction. It'll just take a little more work.
Old May 22, 2010 | 05:35 PM
MADMAN's Avatar
LS1Tech Sponsor
Race cars dont squat GIRLS do!!!!. I prefer the stock springs over any of the progressive springs. If the chassis and suspension is right then the springs arent doing anything after the car starts to move. The shocks if valves correctly along with the suspension will make the car move forward.
__________________
www.madmanandcoracing.com
225-343-9029
Old May 23, 2010 | 05:27 AM
camscam02's Avatar
I love that statement and it is so true. Here's to you!
Old May 23, 2010 | 11:05 AM
robsquikz28's Avatar
Most people keep stock springs and either cut them a bit or even remove the isolater. But keeping the stock springs is because they work with the rest of the suspension, if the rest of the suspension is working perfect.
