Drag Racing Tech
Suspension Setup Help
Old May 31, 2010 | 12:29 PM
bluehawk2's Avatar
Default Suspension Setup Help
I just finished installing a lot of new parts to my car and I am wondering where to start with all of this.
Moser 9" with LCA relocation
TRZ Anti Roll bar
TRZ LCA's
AFCO DA
I have the LCA's in the top Hole on the relocation brackets...............The LCA's are angled up a little.
The AFCO's are 18 clicks from loose on top and 12 clicks from loose on bottom
I havn't checked pinion angle yet, but we will set it to -2 or -3 degrees.
We will scale the car, but I am really wondering where I should put the LCA's and a starting point for the settings on the afco's
Thanks
Old May 31, 2010 | 02:23 PM
bluehawk2's Avatar
I only have the AFCOs on the rear and the LCAs are angled up about 9 degrees from the subframe connectors.
thanks
Old May 31, 2010 | 10:04 PM
BAMALS1's Avatar
I recommend going with the bottom hole on the lower control arms for maximum traction. As far as shocks go, I reccomend kinda stiff on compression and on the rebound adjust to track conditions. The rebound setting will drive the rearend to the pavement. However, every car setup/suspension is different...i'm just giving you info from what I have experienced. Just take a day at the track and see what works best for you.
Thanks,
Jason
Old May 31, 2010 | 11:08 PM
bluehawk2's Avatar
thanks........im just worried about putting the lca in the bottom hole. Im thinking that it may plant and unload if i hit it too hard.
i will try it though
Old May 31, 2010 | 11:15 PM
DMH Fabrication's Avatar
thanks
Most people shoot for around 2 degrees running uphill from the rear to the car.
Old Jun 1, 2010 | 09:26 AM
bluehawk2's Avatar
thanks That is really what I was wanting to know about the LCAs.
Im taking the measurment from the control arms off of the subframe connectors......is that the correct angle i'm looking for?
I have the pinion angle at -3
How firm should the compression be on the afcos? With the bottom **** set 12 clicks from full loose, I can bounce the rear of the car down until it hits the bump stops.
thanks
Old Jun 1, 2010 | 11:41 AM
BAMALS1's Avatar
I would try 6-8 clicks from all the way stiff on compression. Just have to play with and see what it likes.
Old Jun 1, 2010 | 12:57 PM
thanks
Just stick your angle finder right on the LCA. It should read around 2 degrees in the direction stated above (i.e. rear mounting location should be lower than the body mounting location).
Old Jun 1, 2010 | 01:32 PM
onfire's Avatar
Coal Mining Director
You need to set the pinion angle based off the trans shaft angle or you'll break u joints. I'd use a 2 degree difference for movement at the hit.
If your trans shaft is pointed up 1 degree, you'll want the pinion pointed down 3 degrees so they will be in phase when the rear rotates up 2 degrees at launch.
If your trans is pointed down 1 degree, you'll want the pinion pointed down 1 degree so they will phase.
trans down 2 = pinion at 0.
http://www.rosslertrans.com/Pinion%20angle.htm
Old Jun 1, 2010 | 02:05 PM
bluehawk2's Avatar
I use the next to last set of holes on the bracket for the lca..............that got me a little over 2 degrees going down to the rear end.
I took a look at the link above on setting pinion angle and it is set correctly at -3 degrees
