8.8 mini ladder bar times????
Race your car!
Are you referring to the pete Z bars? If so they do work, I wouldn't run them in anything making a ton of power due to the inherent wheelstands that they like to cause from the guys I know that have run that type of setup. That tiny short "ladder bar" tends to really want to lift the car for whatever reason.
Race your car!
I wouldn't run them myself either, but for a stock internal car that's at the track all the time I can see it working... like said by 9sec it's really too much for anything with any power, or a really fast car.
Then again I think Ed Wright is running them on his car and he's in the single digits, so it can work, but I don't like the wheel stands that they generally cause.
9-Second Club
They won't make your car wheel stand
any worse that a ladder bar. You can
watch a round of Stock Eliminator F body
cars and tell who has the PeteZ bars and
who just uses a torque arm and big anti- roll
bar. The PeteZ bars need no anti-roll bar
at all, and allow easy adjustments if it's not
going straight if does do a long wheel stand.
Nothing is going to make a car that doesn't
have a really good torque converter and good
torque do big wheel stands. A lot of cars with
those don't wheel stand. Front travel limiters
and adjustable shocks are needed to control
that. Big wheelies slow you down, about a foot
off the ground does not. It's hard to dead hook
one with no rotation at all. Mine runs quickest
with them 8" to a foot off the ground. Less than
that and it is usually spinning the tires.
thinking of doing to this to my slow camaro will maybe at best run mid high 11s .
will be adding this to a 8.8 with 10bolt tubes ,,
but i need aloot more information .
how do they ride on the street and about at what et will they actually hurt the times ?
wouldnt mind a few small wheelies but dont want some thing ridiculous .
figured this is my best option for my DIY 8.8 rear end !
so bump for more info !!
1 Post
sorry to bring back an older thread, but what do you all consider "any kind of power" my has mods in my sig, should be around 400 on motor and 125ish shot of spray. would it be recomended to run these or a ta im my case?
