Strange rear drag problem help!!
Derek
We did space the rotor hat out with washers, we used a thick steel washer and put them on the axle first, then the hat, and it solved the problem. I don't know why, but for some reason that was the only way we could deal with it. I don't feel too bad about doing that if you have 5/8 studs in the rear, they're strong enough to not have that be a problem, but if you don't, then I would be a little hesitant.
There's no chance that the actual brake disk is mounted to the wrong side of the hat is there? That's the only other thing I can think of that might cause the problem that you're having.
BTW. I don't like the idea of the washers... but I've seen it that way on the orange car Ken and Gary used to have... and several others over the years. Sometimes the ends of the axles aren't right, or who knows what else it is... but if that's what has to be done to make it work there's not much else that you can do.
