Th400 vs 6sp Hp#s, very interesting outcome
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Let me give you a rundown of how my car reacted to drivetrain loss. I put down 469hp with a 6 speed and a 10 bolt. Then I put down 445hp with a 6 speed and a 9". Then I swapped to a th400 and on a 150 shot of nitrous only put down 499hp. This leads me to believe I lost quite a bit of hp due to the swap. The crazy thing is that I only gained 1 tenth in the quarter mile and lost 2-3mph. I drove the 6speed pretty damn good and I miss it, but the th400 is much better to hook on the street and that's where most of the racing around here takes place since there isn't a drag strip within 2hrs of here.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Keep in mind that 2100 DA is likely a high water grain # versus a 2100 DA in the fall or spring that might make it a tenth or so better. Cool air can't come soon enough!
Derek
Derek
Yeah, that's a good 60. What type power do you make? What is your race weight? I believe my car should 60 in the high 1.5s in better air, if I can hit a 1.62 in this weather high 1.5s should be attainable. After hearing severla members talk about my converter and the gas, I can't wait to spray it. I hope it's a beast on the jug![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
car has only had the heater box and a/c removed from under the dash.....power windows and seats.and back seat delete....and stcok 10 bolt with ta cover and moser axles. so i'm guessing 3500 with me in it..may be more may be less
One thing that I seen no one has mentioned is you put a 9" in the car also. Isn't that suppose to soak up alot of hp? Your first pass was on the 10 bolt, and now your running a 9".
i have heard the same thing also...........even with a th 400 it takes more hp.........i guess my car is a freak with the th 400 though........i am .4 faster this year than last year........went from th 350 with the same converter that's in the th400..........and i mean same...i swapped it to the new trans.........and i built both transmissions...
7 Second Club
1 Post
Super slow, on the same day, same gearing, in the same weather conditions? Reason I ask is there have been published results showing the differences in controlled climates, so I'm curious.....
Derek
Derek
#33
I have had this same stall for awhile now- and am putting it in my car with the th-400. My car made 433 with the 6spd. We will see what she does with the th-400.
I will report back with #'s when it gets done.
#34
Pretty close, fall weather, same gears except 4.11-4.10. My point was where it matter'd it didnt hurt the performance of the car. Couldnt tell ya as far as DA was concern'd
#36
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Then why go to a TH400? Less fun on the street and if you can drive a stick, which it looks like you can, the ET diff should not be HUGE... plus, its not like the cari s running 8's , with a high 11 second car the difference is minimal from a well driven m6 to an a3 like a TH400...
Either way, there are way to many changes and variables to say this is a legit comparison from M6 to TH400.
#37
#38
Here is some good info on rwhp loss with other rear ends. To me it seems changing gear ratios has a bigger affect on rwhp #'s than a 10 bolt vs 9" has. https://ls1tech.com/forums/gears-axl...high-tech.html
I will say I've gained 33 rwhp since last year, last year with the 3.42 geared 10 bolt I ran 115 mph in 4000' DA. This year with 33 extra rwhp, a 9" with 4.11's and similar DA I'm trapping 118 or so mph. RWHP numbers may change but cars don't seem to slow down with rear end swaps.
#39
Also, when I went from the 10 bolt to the 9", with no engine modifications, I picked up 1 mph in the traps. Overall weight of the car stayed roughly the same, but I reduced rotating mass by going from et radials to slicks and going with the strange drag brake set up in the rear. Yes you did read that right - I went from the MT et street radials to the MT et drags and gained mph. I should add the 9" inch is a 35 spline and spool
#40
Wow, this thread is going off track a little.
1. I made the th400 swap because I wanted to, the track performance was not there for me. I am also planning on spraying the car in a few weeks and I felt the auto was a little safer choice on the gas.
2. I am not trying to mislead anyone on the swap by no means, I mean I posted almost every variable I could to be consistent.
3. These are my results, dyno and track numbers, not some G-tech or SOTP dyno.
These are my REAL WORLD results. I can't get more real examples.
