Building a race car? Document it here!
I left the tubbs skirt till the end, as I wasnt sure how was best to do it. I nearly have it ready to weld in now.
I finished up the old t- top well with a couple of extra supports to support the Aluminium sheeting.
Still got plenty to do today, I will be using the same methods to build the new trans tunnel at both ends of the car.
Back to work I suppose, catch ya.
10 Bolt with 4:56s stiffined up ,BMR rear race Suspension,Weld Drag Stars
Slp lid BBK Throttle Body with K&N,
Tryng to decide weather to Do The Turbo 400 thing now or just buy Convertor ??
will keep updating Stats
Still waiting on the Auto sparky to look at the wagon as it has no spark!! Hope you guys are getting some things done, catch ya.
Got the floor panels made up...... bit of a job to cut to the body line, but there done now. Didn't get a start on the torque arm hole, hopefully tonight. I will upload some new pics later. Anyway catch ya.
Work looks great though, and you're doing it all @ home. Wish I had all the tools I'd need to do everything myself like that... maybe someday. But for now I have a really good guy that's doing the work and it's coming out killer. Car should be done in about a month.
Yeah it is good to do it all at home. Saves some money and you get to make things the way you want them. Even if you cant do the whole job just doing part of it were you can still helps. Look forward to seeing the car finished up JL..
Thanks JL and Doug for the floor pan advice, I didnt actually do anymore with it as yet! I did start to mount the new VFN hatch. It is abit of a job unless you were seriously reworking the car, I dont think that it is a good idea. I removed the sealer around the hatch you cant weld with it there anyhow, it fitted better. Then moved to the back corners, I played aroud there for abit and actually ended up segmenting the bodywork in both corners. Then the problem went alittle further down so I cut the fender and moved it in about 100mm long. Now it is a nice fit. I got 1 dzus bracket in and the other 5 welded up. So so far it will mount the flat section of the hatch, then im looking at 4 others. I did take a couple of pics so ill get them up later, catch ya.
Any idea what happened? That's a serious explosion! Hope all is well... and if that picture isn't a good enough reason to put a fire system in your car well I don't know what to say.
But, I may be picking up a 2nd job in the coming week or so, which if it pans out I'll be able to acumulate the suitcase of cash needed to finish it LOL.
Have to see how it goes.
i hope i dont become the poster child on how too restart a nitrous car when it stalls.
http://www.youtube.com/watch?v=Qg8iZqUXeOw
On another irrelevant point, atleast you got to test and drive yours, my motor for my aussie car still has no spark and awaiting the auto elec. Car has been ready for nearly 3 months now!!
Got the rest of the brackets set up for the deck area ready to weld on, hopefully i'll get a chance to start it again tonight. So time consuming like the hood, you pull it off and put it on, im getting damn sick of it!!
Catch ya.
