Drag Racing Tech
Which Braille battery?
Old Jul 19, 2012 | 09:02 AM
marksboy7's Avatar
Originally Posted by Pipelayaz
Do any sponsors sell these?
TireRack does.
Old Jul 19, 2012 | 11:13 AM
Mike Morris's Avatar
Save money and get a high cranking Miata battery...
Old Jul 19, 2012 | 11:43 AM
HioSSilver's Avatar
Actually get a deka 30l from battery mart. Same damn battery as the braille for about $100. It's a sealed agm battery to. They have a Deka 16L that will start the car for $72, but it may not have enough capacity for some.
Old Dec 10, 2015 | 11:57 AM
tnmotown's Avatar
bumping this thread back up....
I'm thinking about getting the Braille B14115 and was curious if anyone is using the same one? My car isn't a DD and I put about 1,500-2000 miles on a year. I have no HVAC, and deleted a few other accessories. Will I be ok with it? I have a battery tender that I can keep hooked up if need be.
Old Dec 28, 2015 | 01:06 PM
Troy's Avatar
I run the 11.5 lb battery. I keep it on trickle charge all the time and only get about 5 starts with it at the track. I carry a portable charger to help it from now on.
Old Dec 28, 2015 | 11:18 PM
01ssreda4's Avatar
Old Dec 29, 2015 | 12:13 AM
tnmotown's Avatar
That's my only downfall, I don't want to be stranded somewhere if it doesn't have enough juice to crank over.
Originally Posted by 01ssreda4
I've checked that one out also. But isn't it close to the same specs as the Braille 14115? Just a few pounds lighter and a few bucks more.
Old Dec 29, 2015 | 11:13 AM
Troy's Avatar
If I had to do it again, I'd take the 4lbs and get the bigger one
Old Dec 29, 2015 | 04:55 PM
01ssreda4's Avatar
So far mine has never failed to crank but there was a couple of staging lane times I ******* wondered. Ya know wait crank move 10 feet kill it wait crank move it 10 feet kill it etc.
Old Jan 17, 2016 | 09:19 AM
99french's Avatar
I've got the Braille 9.5 pounder. Mounted in the stock location. If I daily drive it then no problems. But if I leave it off my tender for s week and don't realize my little guy turned my map reading lights on then I get stuck at gander mountain.
Old Jan 17, 2016 | 01:09 PM
01ssreda4's Avatar
Ive come up with a solution. We want to run these lightweights but don't want to be stranded so I purchased this: It's going to ride with me and cover my *** if the lightweight decides to not be up to the task.....weighs 18ozs AND will directly run laptops if you needed to do tuning and not worry about your laptop battery not making it through the tuning session.
http://themicrostart.com/products/micro-starts/xp10/
Old Jan 17, 2016 | 05:19 PM
  #32
99french's Avatar
That is $210 well spent. On my birthday list
Old Jan 18, 2016 | 11:10 AM
  #33
01ssreda4's Avatar
Bought mine on ebay for around 130.
Old Jan 18, 2016 | 06:00 PM
  #34
NewOrleansLT1's Avatar
I had one of those batteries before.. Can't leave nothing extra on.. No radio, no dome light, and head lights must be turned off before you turn the car off.. It will leave you stranded.. I put in a small Wal Mart battery for a 4cly Honda and it's been good ever since
Old Jan 23, 2016 | 04:12 PM
  #35
Vicious95Z28's Avatar
01, yours is mounted in stock location, right? How do you mount it? Is there a adapter bracket?
Old Jan 24, 2016 | 08:38 PM
  #36
01ssreda4's Avatar
Took a piece of flat aluminum bar from home depot and used the stock bolt location on the wheelwell side bent it up and over the battery then to the bolt on the radiator support.
  #37
01ssreda4's Avatar
Just tried it on my first dead battery and it worked awesome.
Old Jan 25, 2016 | 12:18 PM
  #38
You have a pic, 01? I'm one of those "learners", lol!
Old Jan 26, 2016 | 04:58 PM
  #39
01ssreda4's Avatar
Old Jan 26, 2016 | 09:22 PM
  #40
Awesome brother, Thankyou, once again you're a great help!
