Wiring Harness Question
I can't remember what these actually do, can anybody remind me?
Where does that ground strap go? There is another ground strap higher up on the wiring harness, which mounts to the body I believe. I believe the weather pack goes to my driver's side O2 sensor?? I forget.
The following pictures are the wires on the harness that go into the vehicle, through the firewall, passenger side. What do these do? I'd like to fire the motor this weekend and want to know what is needed.
The two connectors are to be run through the hole in the firewall behind the PCM and the grommet seats it off. The connectors plug in to other connectors behind the passenger side kick panel that are the female versions of the ones pictured.
I am not sure what every wire on the two plugs with the grommet are for, but I'm sure that you need them to crank the car. Most likely have the signal wires for oil pressure, engine temp, voltage, check engine light, etc. As well as the switched ignition to the PCM and the starter crank signal wire from the BCM. The car probably will not even crank if you leave those unplugged.
This was by the passenger side fuel rail. had a decently long cord. Where's this go and what does it do?
This one is attached to harness that runs along the passenger side fender. Almost down by the battery.
This one was right near the 2 ECU plugs, really confused on this one...
I have the clutch pedal depressed, so that clutch sensor is okay, but I found 2 connectors and 2 empty plugs that I'm not sure about. Would these cause the motor not to even start? Starter isn't even going out. With the starter mounted, I have the wire attached to the starter, going to the pole on the solenoid that is closest to the engine block. The HOT from the battery is on the pole farthest away from the block.
I think these plugs and connectors are the problem??
Here are pics, I'm thinking one of these is preventing the circuit.
First are the 2 plugs I don't get. They don't look like they fit into the empty connectors.
Wires look to be pink and gray on this one..
These look to be gray and black with a gray stripe
Empty Connectors:
If I remember, this is by the clutch pedal, if the clutch pedal were NOT depressed, this switch would contact.
This one is by the brake pedal. Same deal, this would contact if the brake pedal was NOT pushed down.
More shots, just blurry.
I'm completely lost now.
Just a recap, there is nothing in the interior, just plugs laying everywhere. Engine is all connected, except for the (3) plugs seen in post #9
What inside the vehicle could prevent the starter from trying? Is it in a lock out, thinking it was stolen? I had everything apart for at least 6 months.
Lastly, I snapped a pic of the starter wires, before I gave up tonight.
**Edit**
If the BCM is one of the two smaller black plastic boxes, yes, those are connected as well.
