rubber on back wheel wells
geddex burnout guard - never tried it
wax - hot rubber works right through wax. No good
Most of you are running Nittos/Dr's, 26" ET Streets. When I had those tires, these products were ok cause most of the rubber was thrown UNDERNEATH the wheel well. 28" ET Streets throw rubber EVERYWHERE. I have to clean my rear window, t-tops and even hood sometimes. The rubber that is the biggest problem, is the rubber you see that looks like it was poured on the car. That was hot hot rubber and it is a bitch to get off. The little particles of rubber aren't that bad. Matter of fact, I have found that those come of easy if you let them sit on the car for a day or 2 and even put cool water on them to harden them more. They just kinda wipe off.
and Tim98 you're right, big tires throw **** everywhere, i get it on my rear window, doors, t tops, hood, you name it.
Tim, I hear ya, the nova throws the stringy rubber all over the quarters and trunk! Usually takes me an hour and a bunch of shop rags to remove it if I don't use the guard beforehand.
derek
I was so desperate at one time, I tried Pam cooking spray on a recommendation from another racer...
disaster.
