Need pics of pin on firebird hood mounts please!
I know racecraft makes really sweet rails for Camaros, but I am a Firebird guy and the shape of the fenders are different, racecraft even says they cant be adapted.
Tax return just came in and I need to order my VFN hood extended to the windshield. I just dont know how to mount it. I know rails are stronger than brackets but I also am not paying a ton of money for custom brackets.
So give me some ideas here! I have searched until my fingers hurt and found many threads but few pictures. If you have Camaro rails adapted to the Firebird then IM REALLY INTERESTED!!!!! And if you have brackets im also interested in seeing how you did it and how the hood came out.
Thanks!
EDIT: Post #11 in this thread
https://ls1tech.com/forums/drag-raci...zus-rails.html
https://ls1tech.com/forums/drag-raci...lled-pics.html
I've also heard of people buying the Racecraft rails for the Camaros and modifying them to work on Firebirds.
Either way if you end up making your own brackets post up some pics, I'd like to do this in the near future.
I'm going to end up ordering the camaro rails and modify them. If I can do a mini tub install hopefully I can mount a friggin hood.
Give me a day or two, I'll snap some pics of how I did it
It's not the prettiest I've scene, but they work
I'm sure you could make them work on the 98-02 Birds
csjta2- did you use the bolt on rails of the 3rd gen, 1 piece?
https://ls1tech.com/forums/drag-raci...ch-diet-3.html
check my build thread I took alot of pics of them, UI used the bolt on, ans they have a lot of the little 6-32 or whatever hardwear nuts and bolts. That was spaced just right fot the flat spots in the lip on the fenders for them to fit. I dout all of them would line up with a spot to ptu all the bolts on the firebird fenders. But you don't need everyone, I think you could get them to work. But I haven't seen any of the other styles too?
I'm going to order the vfn 5" sloped and extended hood tonight and probably order the side rails and dzus fasteners as well.
Mr.elec. I'll get some of those pics up after work. I think I also have some pics of them still attached to the hood when I blew it off last summer at going through the traps. So I had to reshape these ones when I put them back on.
