Just finished Battery Relocation. Now just clicks.....
#61
The relay is a 12 volt Littelfuse flasher relay from O'Reilly's. I disconnected and reconnected the battery (reset the security light) and it started with a little labor. Thought it was just that I hadn't had the car running in a while and the battery was a little low on juice. Went for a 20 minute drive, brought it home, and shut it off. Tried to start it again and it clicked a few times before the 200 amp main power fuse blew. Replaced the fuse and jumped the car and it started. It is currently idling in the garage. Figure I'll let it idle for about a half hour and try to start it again and see what happens.
