Just finished Battery Relocation. Now just clicks.....
Just moved the battery to the back. The battery is brand new. Have had it on a trickle charger for almost a week now. Ok, here's the story. Bought the car and it had the factory V6. Swapped in the LQ9. Moved the battery to the back. Ran a 2ga wire to the front right where the factory battery went. Bought a distribution block. Cut the factory + cable and used the factory wires. Ran them to the starter, alternator, and the fuse box. I started it a week ago, but it would just click the first couple times I tried. Then it just started. I didn't think much about it then. I have the battery grounded about 16" to the seatbelt bolt in the back passenger side. Block has 2 grounds. One running from the passenger side block the frame rail, the other is running from the drivers side block to the drivers side frame rail. Anyway, I am getting good power at the battery, distribution block, and alternator. They all load tested good to. While cranking they all stay about 9.8-10v. It just clicks really fast when I try starting it. The guages also reset after I get done. I can get pictures if anyone needs them. I just need to get this figured out. Oh, starter and alternator are brand new.
check voltage at the battery and at the starter while cranking /trying to crank...also check the ground from the battery to the seat bolt is tight and clean...do you have a ground from the block to the frame ?? motor plate or rubber mounts ...start there ...hope it helps
Like stated above, check all your connections. Did you clean all the paint off the seatbelt stud for your ground? Check for high resistance between your cable connections. Check your voltage at the battery while trying to start, and check at the starter while trying to start to see if you have a voltage drop. Maybe your Positive wire is to small.. although I'm pretty sure lots of guys have done the relocation with 2ga.
Mine did the same bs when I moved mine to the back. I had the block grounded to the frame up front the battery grounded all the way to the block just to make sure the grounds were good. Huge welding cable on the positive and negative side. I finally stopped being hard headed and tried the stock cables with a small battery up front like a buddy said and no more damn clickity click click click.
I'll let everyone know how the starter voltage checks out. I will also be moving the battery up front to see what that does. I may just call it quits and keep it up there!!!! J/K. I hope to get it figured out tomorrow. I really need this thing running!!!
We have been fighting this same problem for a few weeks now. In fact I posted a question about it in a different section a few days ago, and haven't gotten a response yet. Here is what I had posted.
I'm not trying to hijack, just add our experience to try and get this resolved.
Sean
OK, we relocated the battery to the back of the car this year. When we got everything together we tried to start the car and it just clicked. No big deal, probably just low on juice. Charged it up overnight tried again and the same thing. So then we thought the battery we had wasn't up to the task. Got a new big battery, same thing. Then we thought the starter was bad even though it was somewhat new. Got a new starter and still the same. The battery is wired with two stinger 4ga wires from the battery to the front, and the same down to the starter. In reality a single 4ga should handle the load, but we beefed it up just to be sure.
The starter seems to stay engaged, and when it is that is when we have the problem. If it is not it cranks and starts just fine. If we put a booster pack up front it fires right away. I cant see the wire not being enough, the starter is new, the battery is new, and when it does work it cranks strong and fires right up. What the hell can it be?! Do we need to space the starter down some? Lets see what everyone thinks.
Thanks,
Sean
P.S. This is a lower compression (370ci) turbo motor.
Thanks,
Sean
Sean
If your talking about checking resistance on all the wires I've done that. Only one I didn't check was the starter. As stated above, I am goin to do it tonight. I'm sure that is the problem. Try reading before posting.
If you moved the battery.. and it's not working.... the solution is simple: It's not wired right.
Look @ what connects to the battery, trace the physcial wires to it when it's up front, and do the same in the back...
If something isn't hooked up, that's the problem. ALT needs to go strait to the battery, and one wire off the battery thru a kill switch up to the power block in the front of the car. It's very simple really.
Clicking... means bad connections..... it's getting enough power to do something, but not start... it's a bad connection. Period.
Come on guys, you dont think we wired it right?! Seriously? We have wired entire cars, Chris is an electrician by trade, I work with electronics all day. The car is wired same as it was last year. All of the under hood wires that went to the battery are now on a firewall post. Last year we had a wire from each terminal of the battery ran to the same post. Now the battery is in the back with wire run from the battery to the same post. AKA it is exactly the same as last year. The alternator is wired to the battery side of the switch just like it needs to be. It is pretty impossible that there is a bad connection on the pass through terminal, but honestly the only thing we haven't tried yet to going straight from the battery to the starter.
Sean
Sean
