Pre-Loading Stock Rear Sway Bar
My car launches really hard, and pulls the entire left side of the car up. I was thinking of trying to limit some of this motion by pre-loading the suspension in the rear. Has anyone ever tried shortening the driver's side end-link on a stock sway bar set up? Is a 19 mm bar with poly bushings even stiff-enough to make this change effective?
LS1Tech Premium Sponsor
It is way easier to just bite the bullet and buy a anti-roll bar, doing it right the first time will save you a ton of headaches in the long run.The anti-roll bar will make a night and day difference and alleviate the issues you are having launching.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
With a good anti-roll bar there is absolutely no need for an airbag.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Getting rid of the airbag is one of the first things I did when I traded my vette for the camaro I have now. I took the stock sway bar off and put in the adjustable BMR and the car leaves straight as an arrow and you can damn near launch it with just your thumb and index finger on the wheel.
I just didn't throw it on there either. I had the car scaled with the driver in it and preloaded the sway bar. No twist and leaves straight.
To the OP, just buy a dragbar. You can't steer with your fronts in the air-Dragbar is alot cheaper than bodywork.
That kinda thinking is why your car squats like a girl taking a **** in the woods and mine leaves like an animal.
seriously, truth to what I say here but I'm just bustin your ***** a little. You can take a little ribbing can't ya?
Race your car!
Yeah sure the car used to squat... no problem saying that. But, it also hooks on zero prep, as well as it does on perfect prep... if that's a bad thing then I'm guilty as charged. Probably would have been able to run some #'s on the street like it did on the track too
What it will do when it's back together? Who knows... it might just blow the tires off at the hit when the track's not there for all I know.
Race your car!
Gizmo have you tried increasing the spring rate, to see if actually changing the spring itself, rather then playing with the air bag would do the same thing?
I would bet good $ that if you did, the same or better results would be possible. Certainly be able to know what the actual spring rate is, and would be able to replace with the same spring rate every couple seasons or whatever to keep things 100% and consistant.
That's the other issue with bags... as springs settle over time, the bag pressure will need to be changed... alot of times guys get into the "it worked there before so don't change it now" mentality.. and then the performance will get chased. Airbag's themselves do wear out, as do springs, so now you have 2 things doing the same job that can wear out/change....
Not what I want to deal with when trying to keep a car consistant enough to be able to repeat within .01 every round, for seasons at a time.
