28" front tires rubbing the fender?
I just put a set of Weld prostars that are 15x4 with Mickey Thompson 28x7.50-15LT tires and while on the jack stands the tires are very close to rubbing the fender but this is with the suspension unloaded. I am running a 5/16 spacer so I did not have to grind the calipers.
Thanks
Thanks
28's will require taking all the inner wheelwells out and that spacer will have to go and a little camber to get them to tuck when front comes down to them.
They will help your et a little and allow you to hit the tree harder if you get them to work for ya. Stock Eliminator guys love them.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
