3000lbs was heavy, had to lose more weight
the dash really isnt that bad, i've had mine out a few times. if you do pull it to remove airbags and everything, you might wanna consider hvac block off plate, and removing the rubber/insulation mat against the firewall. but with this car being your dd i dunno your thoughts on no ac/heat.
i guess when i get around to pulling the HVAC i'll **** or get off the pot.
