whats everyone using for front runners on the street?
got some cheap arizonian tires on some pro stars i traded for. got 90% of the way to the track tonight when i started getting a bad vibration. pulled over to discover a big *** bulge in the tread. turned around and limped it home, put on a buddies spare pro star and was gettin ready to go out and try again when i decided to check the other tire again and found it had a bulge too. i need to know what u guys are using. dont need a tire blowing up and takin out my fenders
all you guys running the cheap *** radials will learn eventually. I was one of the guys who said "it will never happen to me" I had them on the car for a few years before I even had issues.
But just like the OP the steel belting blew out and created a buldge - just lucky that i caught it before it caused damage. They are not meant to carry the load of our cars or speed
Run 8ply sportmans with my 15's now, but when I was rolling around on the 17x4's I had Hoosier's on them. I, too, had a bubble come up in the side wall. Put a set of motorcycle tubes in them and never had another issue until they wore out the tread.
Hope this thread is acceptable for this question.
Got a set of draglites off of Craigslist, and the front tires that came with them rub against my bumper and wheelhouse. Guy I bought from had on a 94 with no motor, so it was impossible for me to see how they fit on his car fully weighted down. (He swears there was no rub) Anyway, mine is a 95 w/ OEM suspension, (pics below) obviously the tire is too tall, and I want to pull the trigger on the MT sportsman 8 plys ( 26x7.5-15) but the tires that rub are (205/70-15) which is also supposed to be a 26" tall tire. (According to http://www.jekylhyderacing.com/HeightofTires.htm)
Just hoping that with being the same height, I am not going to have the same prob with the MTs rubbing. The fronts i have are the "Jegs" style draglites that use the OEM acorns, and I know they sport a little more offset to accommodate the brake caliper, but kinda hoping that it is both a height and width problem with the current tires. Anyone else ever have this issue?
http://i1302.photobucket.com/albums/...psc50257ca.jpg
I will never understand why wheels/tires is where people decide it's a good idea to cheap out. "Oh yaaaa know, they're just what keeps you and the guy next to you safe, I think I'll put some 20 dollar VW fronts on, sure they are rated for a 2,200lb vehicle at a max speed of 70mph, but that shouldn't matter, right?"
Run something that's designed for what you're doing. MT/Hoosier/M&H/Goodyear all make several bias ply and radial designs for skinny front runners in sizes from 15" wheels to 18" wheels.
