Why is my th400 running so hot? UPDATE 6-27-11 Page 5
#69
I got the cooler in and took it for a ride today for about twenty miles of highway with some mild city driving. Right out of the gate it was a whole bunch cooler. I could only get twenty miles in due to throwing a belt.
After this drive I only got to about 180 when I arrived home. I would normally be around 220 plus. I still believe that I have a problem with something due to how the transmission and converter feel in the upper rpm's. Feels like it is slipping alot while in boost.
#71
Race your car!
Ive got a TH400 with a 5K converter and 4.11s in the rear. My tranny temps stay pretty cool. There's a couple of us that use this cooler from Summitracing. Its one of their house brands but its big and works great. After a pass at the track, when i return from the pass the cooler is still cool to the touch. Even after highway driving you can place your hand on the cooler and its tolerable.
http://www.summitracing.com/parts/SUM-G4969/
Heres a pic of it on my car.
#72
I wish it was but it feels like I'm pushing thru the converter. I hope it's just that I have a mismatched valvebody and pump (like Greg @ FTI suggested). I still have that gear that should have been there by now (3.5 ring and pinion) to install when it gets here.
#75
"Feels like it is slipping alot while in boost."
Maybe, do a data log, then do the math, and see what you are getting for slip?? That way, if/when you go converter shopping, you have some data to discuss.
http://www.tciauto.com/Content/Stati...ookieSupport=1
#76
Brand new converter I'm not going shopping. Converter has already been sent back to get inspected by FTI. All was good on their end.
I found ut why I am throwing belts also, I have a broke power steering pump bracket allowing the pulley to pull forward.
#78
Yes you are correct. After I get it up and running again and get the 3.5 gear along with a new valvebody or transmission (spare known good transmission I have for another car) then I will look at that. I have talked with Greg at FTI and he assures me that it is not the converter as he has already inspected it. He also built it for my build.
First I have to find a power steering bracket so I can drive the car again. I also awoke to a wrecked family car that someone did a hit and run on last night
#79
ive had similar problems with mine as well i had a derale cooler with a fan built on to it. i was seeing 200+ with 20+ mins of st driving. i just installed an indenticall cooler next to it to see if that would help. I was suprised cus i thought the first cooler was plenty with the fan on full blow but i guess not, they are expensive coolers so i hope this does the trick
if not then i go back to square one. cus the fti converter i have has just been refreshed and re-done since when i got it new it was bugered up. but fti took care of me (mad props to greg)
