Drag Racing Tech
Solid roller?
Old Jun 4, 2011 | 08:19 AM
INTENESS's Avatar
Default Solid roller?
Im looking to go solid roller set-up,I'm currently using a stock pcm will I be able to use the stock computer to work with a solid roller setup?This is a 2001 camaro car is street driven and I want to be able to pass inspection.What type of machine shop work will in need if any?
Old Jun 4, 2011 | 10:41 AM
studderin's Avatar
PCM will be fine, unless you want to spin into 8,xxx rpms NYS stuff will be fine.
Good valve springs, and valve train setup... adjustable rockers.
Old Jun 4, 2011 | 11:06 AM
tektrans's Avatar
How high you gonna spin it? Stock pcm good to 8k-ish max.
You lookin to bump that rpm range or just for valve train stability?
Depending on what you're lookin' to do-u may have to look into cam, lifters, pushrods, intake/tb swap etc.
Stret driving will be fine, may need to adjust rockers every now and again. Emissions, I don't know how a solid roller set up affects emmisions.
Old Jun 4, 2011 | 03:55 PM
INTENESS's Avatar
Looking to solid roller everything camshaft,springs and lifters etc,spin it to max 7800.My current heads are AFR 225's are these going to get the job done?I dont mind haveing to adjust the lash every now and then.
Old Jun 4, 2011 | 04:21 PM
SSPerformance's Avatar
Call gary im sure he will help you out
Old Jun 4, 2011 | 05:45 PM
INTENESS's Avatar
I will pick Garys brain on it just want to see if anyone has been running this type of setup to give me feedback.
Old Jun 5, 2011 | 08:59 AM
Firehawk441's Avatar
I went 8.6 @ 159 with a stock computer and Solid Roller...
Old Jun 5, 2011 | 09:27 AM
INTENESS's Avatar
Alright so stock pcm will be good to use thats good to no.Now to I need to do machine work to get the solid lifter to work and do you think my afr 225's will get the job done.
Old Jun 5, 2011 | 10:34 AM
BADD SS's Avatar
you can spin hydraulics to 7800.... no prob.
If it's just the rpm range thats making you want to convert. Either way you need great springs... light valves, etc.
Old Jun 5, 2011 | 10:47 AM
tektrans's Avatar
Yeah you "could" but........If I was gonna spin that high I'd want a more stable valvetrain.
How much rpm is the stock oiling system good to?
I don't see why your AFR heads wouldn't work well with the new set up.
tektrans's Avatar
What intake are you planning to use?
Old Jun 5, 2011 | 10:49 AM
INTENESS's Avatar
No dont just want the rpm's Chris looking to go solid for the hp pick-up,Just throwing around the idea.Well I know there are bunch of people with a solid roller set-up driving it around on the street just want there feed back.
Old Jun 5, 2011 | 11:33 AM
Heads will be fine with a spring change.
Shaft Rockers
Link Bar Lifters
No machine work
Old Jun 5, 2011 | 12:37 PM
BADD SS's Avatar
True just stating it's very doable. We had mine at 7700 on the dyno and at the track, but were extremely careful with lifter preload, 3/8" manton pushrods, some really nice valve springs, lightened valves and so on.
Good luck with what ever route you go dave.
Old Jun 5, 2011 | 12:44 PM
INTENESS's Avatar
That was my next ? im guessing my fast 92 is not going to work?
Old Jun 5, 2011 | 12:46 PM
INTENESS's Avatar
Shaft Rockers
Link Bar Lifters
No machine work
Thanx for the heads up
Old Jun 5, 2011 | 01:18 PM
We've gone 9.61 N/A and 9.19 on a 100hp plate on Barrys Nitrous car. He still has a FAST 90 on his 403. The Direct Port hasn't even been used yet. Then it will get hit with both.
How fast are you expecting to go with your current engine?
Old Jun 5, 2011 | 02:07 PM
Here's a picture of Barrys engine with a FAST 90. Just a Nitrous Outlet D/P and Plate.
Old Jun 5, 2011 | 02:39 PM
studderin's Avatar
baller
Old Jun 5, 2011 | 07:13 PM
tektrans's Avatar
Usually with the higher rpms the car may like a shorter runner than the FAST has- but 7800 isn't "that" high.
I don't think there is anything wrong with designing a solid roller set up around the intake you have.
Now if you were thinking carb style intake, which IMO I think would be the best choice, you could go with the Mast Motorsports intake and top mount TB. I don't think u will fnd someone who disagrees that would make the most power with the upgrades you are considering.
