what do you guys torque your drag wheels to?
I recently had a mishap at the track changing from 28 to 26" tires and twisted a stud off. They were torqued at 80 ft/lbs. Is this too much? I put anti-sieze on the studs and lugs hoping this will resolve that problem from happening again
Just seeing what the propper ammount would be. I use both racestar and draglite wheels.
Thanks
Thanks
https://www.rsracing.com/tech-wheel.html#torque
Maybe, check w/ the wheel mfgr and see what they say??
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
I'm betting they were not of the same quality as the ARP studs...Can you say "Ho Chi Min"??
Another problem I've dealt with is, the OD of the "el cheapo" lugs is not concentric w/ the thread bore. This results in the OD galling up in the bore of the wheel. Some I've seen were so bad, I could just look at the end and see the oblong OD...
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Lastly, the lug pattern on the axle is fubar, and/or the studs are not at 90* w/ the axle flange....
Lots of "stuff" to consider.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
the Streetlites on my 55. After the install and torque, I found that the ends of the hex corners and the ID of the washers were galled up, w/ metal shards torn out of the washers.
Got some detailed pics, sent them to Billet Spec...Got the usual bullshit reply:
"We've never seen that", and referred me to Gorilla.
Gorilla said "those are not our washers. I'm sending you a new set of lugs and our washers."
The new washers have a much smaller ID and allow better load distribution when torqued.
IMO, the original combo did not allow for proper loading of the fasteners, as a good part of the applied torque was used in overcoming the friction caused by the lug/washer problem.
