What spool do I buy for stock 10 bolt
Here you go!! lol Call them tell them what you want and they will help you out. Get me a set too lol
http://www.moserengineering.com/
Internet Mechanic
http://www.quickperformance.com/Products/spools.htm
MINI SPOOLS:
MS75-26 GM 7.5" 26 spline (steel) $85
http://www.summitracing.com/parts/RMG-78-7526-1
I did a on it. This should be correct. I would still contact and verify
MINI SPOOLS:
You don't, and if you put a mini-spool in it and drive it on the street you should be shot.
If you're stepping up to a spool then you'd be much better off investing in a rear end worth a ****.
Race your car!
Do yourself a favor and put the money towards a good rear end. Even if you spool a 10 bolt the tooth size on the gears is too small to take any real power. The axles won't hold up either, and will fail.
Save your money, scrap the thing and put at a minimum, a 12 bolt in the car. (auto car you can get away with a 12 bolt for quite a while without any problems, well into the 8 second zone anyway) Stick car I'd put an S60 or 8 inch in it and be done with it.
MINI SPOOLS:
MINI SPOOLS:
Internet Mechanic
Like said, start searching. Contact Manufactures. I personally would never spool a 10 bolt. Just throwing out ideas.
I did some more searching and some site do show 26 Splined for 4th gen's. I do not have anymore sitting at my house to go count them.
In the end like JL said, no point with exception of buiding a 4WD S10 off road truck.
