Drag Racing Tech
Where to Shift? Based on Dyno Graph
Old Sep 11, 2011 | 10:39 AM
OLDSCHOOL85's Avatar
Default Where to Shift? Based on Dyno Graph
What rpm and mph should I set the shift points in HP Tuners based on dyno graph?
LS1, Patriot LS6 Heads,224/224 .581 Cam,Fast 90/90,Headers,
Stock Automatic(3600 Stall),3.23 Rearend.
Old Sep 11, 2011 | 06:34 PM
Duffster's Avatar
I would say 5500-5700 on your graph... that way when you get the new gears, they're pulling hard....
Old Sep 11, 2011 | 07:12 PM
studderin's Avatar
id start at 6500, see what the car runs the fastest with
Old Sep 11, 2011 | 07:51 PM
JS01's Avatar
Depends on RPM drop but probably 6400-6500
Aim for whatever nets the most avg. horsepower.
Old Sep 11, 2011 | 08:27 PM
fenton06's Avatar
I agree with what the two above me said
Old Sep 12, 2011 | 01:20 AM
Duffster's Avatar
If he waits to 6500, when the next gear is engaged, the torque where it reengages, will already be droppin off. Torque is what gives you speed/acceleration. HP is what keeps it there.
Old Sep 12, 2011 | 10:42 PM
dannyz's Avatar
Does not seem to work that way.
I have the gm hotcam, a bit smaller then what he is running.
I went from a 12.30 down to a 12.09 just by raising my shift points from 5900rpms to 6300. Runs were back to back, less ten maybe 15 mins in between.
His shift extension will determine how far down in rpms he will drop as the next gear is engaged.
Shifting any sooner then 64-6500 rpms will mean that much less time in the powerband and will hurt his et.
Old Sep 13, 2011 | 06:55 AM
HioSSilver's Avatar
^^^ nice job with a hot cam.
Old Sep 13, 2011 | 09:20 AM
thunderstruck507's Avatar
Shifting before his HP even peaks will not make the car faster.
My car peaks at 6000rpm and has gotten faster with each raise in shift rpm from 6200 all the way to 6500rpm.
I won't spin higher due to 98 rod bolts.
Old Sep 13, 2011 | 09:27 AM
Stippy17's Avatar
Yes I agree with the others. Try shifting around 6500 and see how that goes. Then you can adjust from there.
Old Sep 13, 2011 | 09:57 AM
JL ws-6's Avatar
Race your car!
I'd shift it right below the limiter.. 200 rpm maybe just so the car won't hit it. I went thru this experiment with my own car at a couple different levels of power over the years, you will get to a point that shifting higher won't get you any additional gains, but I never had the car perform worse by doing it.
Try whatever ya want but I'd be surprised if that doesn't net the fastest times.
Old Sep 13, 2011 | 10:09 AM
speedtigger's Avatar
Old School Heavy
This is not correct thinking. You are trying to maximize horsepower under the curve when selecting your shift point.
Cars typically run the fastest numbers shifting just past the peak. Most guys start by shifting at peak then extending it 200 rpms at a time until they find the fastest E.T. On automatic cars, some people find that shifting at a little lower RPM on the 1-2 shift can work well, but this might not be true with your 4L60 transmissions because of the wide gear spread between 1st and 2nd.
Old Sep 13, 2011 | 10:44 AM
AChotrod's Avatar
My car peaks about 6450 then it doesnt really drop off till about 67-6800 I shift between 68-7k for the fastest times.
Old Sep 13, 2011 | 11:00 AM
Stippy17's Avatar
The OP and my dyno #s are very similar. Mh car dynoed at 398whp/378wtq. My car consists of 227cc Patriot Heads w/ 59cc chambers, 224/230 Comp Cam 581/592, LS6 Intake, P&P TB, Yank 3600, & 3.42s gears.
I have gotten my best ETs shifting right above my peak hp. I peak around 6250, so I shift around 6400-6500. That's probably around where your car will like to be shifted too.
Old Sep 13, 2011 | 11:42 AM
BADD SS's Avatar
~6500 i agree with studderin, just start there and test a
Little higher and a little less. My bet is 64-6600 will run the fastest.
Old Sep 13, 2011 | 08:46 PM
JS01's Avatar
HP is work over time.
That is what equals acceleration.
Old Sep 13, 2011 | 10:26 PM
minytrker's Avatar
I would start at 6400rpm then do 6500rpm..it will probably run best around 6500rpm.
Old Sep 13, 2011 | 10:51 PM
ska4life07's Avatar
HP and torque exist together.
Old Sep 14, 2011 | 08:37 AM
JL ws-6's Avatar
Race your car!
HP is just a calculation of TQ and RPM.. and they're always going to cross at the same place..
Determining the best shift point I would look to try to keep the car in the highest HP as much as possible, and not let it drop any power in the power band then you have to.
Try to keep the engine in the best "average" power you can, wether that be before, or after peak HP.
(Hence why shifting higher usually only helps and doesn't hurt, unless the engine dramaticially falls off due to running out of air or another causing factor)
