What did you do to the steel part of the dash
My idea was to drill the steel part that is hidden by all the plastic and dash pad and maybe hole saw the thing if I can find a metal hole saw. I will be leaving my windshield in but I have all the hvac stuff out and won't be running a/c again. So what did you guys do? And the dash plastic and pad is all going back in.
ya was that you the PM about a PN for the blower? I never got back to that and closed it sorry.
But I used the stock blower, its quite, the grainger one was loud.
Ya I posted pics, I used the fiberglass snail shell part. But Had to cut it were the outlet was ans screwed that to a alum angel iron frame. Had to use some piece and epoxy to seal it, so it dosne look super nice. But worked great.
I still haven't cut my lower dash bar but have some some other cars and it was fine.
1 Post
Are you talking about cutting the cowl off where it comes inside the car. If so, I cut the entire cowl back flush with the dash and just left the upper metal to support the dash. It's sort of similar to how people cut the cowl flush with the windshield on the outside of the car except it's on the inside. I wouldn't recommend doing it because you will run into all sorts of leaks (water/air) due to it not being sealed off from the factory. I lost right at 8 pounds by the time I cut everything out. You have to remember water comes in there from the windshield so you'll have tons of water leaks if all of the cowling outside doesn't get blocked off.
The dash pad and plastic piece do bolt rite to it that's why I figured to drill it or hole saw the thing and not loose a ton of structure but might be beneficial weight wise to get some fat out. And when the pad and dash plastic is back on you will never know
1 Post
It wouldn't be bad but by the time you punch holes in that piece then block off the cowl on the outside you probably wouldn't be losing much weight. It goes to the outside of the car so if it's left uncapped you would have 100+ mph winds coming in the car. I have done it so I'm just trying to tell you what problems you will run into.
