Santhuff Suspension Specialties - FTMFW!!
Just got a set of Santhuff front shocks. These things are nothing short of awesome. Everything about them is top notch. Lower mount is a heim style joint with cromoly t-bar, the shafts are 3/4" diameter with a 5/8" mount.
They do require some fab work to get them in, but well worth it.
Uses a standard coil-over spring, and they are 12.4lbs lighter per side than QA1's
Going testing today for the YB race at cecil. Hopefully will have some good results.
AFCO uses a standard 14" coilover spring. Strange you can go either way. S5069 uses a stock style replacement (like QA1) which fits into the upper spring perch, S5071 uses a standard 14" coilover spring.
Which makes me wonder what the weight difference is between S5069 and S5070 (with Hypercoils).
