Custom Mustang Trans Fab (faceplated)
Hey everyone, I know its a Ford but I thought I would share. About mid way through the 2010 season, I got the natorious 3rd gear synchronizer problem in my TR-3650. With starting a new family I did not have the funds to buy the upgrade kit for the 3650. After talking to my dad, we decided to face plate my transmission. All of the work was done my me, on manual mills and lathes with the exception of the tig welding. That was done by my father.
Started out by blue printing the dog rings to get a rough idea of where to start milling
Dog rings were made out of 8620 raw stock
The gear side in process
The Slider side for engaging 2nd gear
Turning down the gears to remove the synchronizing teeth and for the shrink fit of the dog rings
Once the correct tolerances were made for the shrink fit, the dog rings were put in the oven and gears put in the freezer. After a while they parts were mated together
After the were cooled down, they were put back on the lathe to be faced to proper size
For the 3rd-4th slider, we made a whole new slider. we turned the sides down of the stock on so just a hub and splines remaind and then mated the 2 and tig welded them together
during some test fitting, we ran across some clearance issues that were easily addressed
once the clearance issues were fixed, the rings were welded to the gears instead of just relying on the shrink fit
All the parts ready to install
Re-assembly
Re-assembly
The trans was put together with the stock shift forks. We new they would not last but we were not sure for how long. I had been messing with a clutch stop to only engage it enough to make the quick shift. It however gave me issues with 3rd gear. This, i think weakend the shift fork and on July 8th of 2011, it decided to let go.
It took out 4th gear with it. After analyizing 4th gear, we decided it was not strong enough so we started over.
Machined off old dog ring
Machined down 4th gear to make a thicker hub
Machining new dog ring
once the dog ring was done, the input and ring were mated and faced down
Ring welded to input
Getting ring up to 1500 for oil quench heat treat
after oil quench, the input was placed in an oven at 500* for 3 hours for the . This is the input after it came out
By comparing the old and new inputs, you can tell how much beefier this new one is
old:
new:
old:
new:
Took the car out for a ride a while back, first time this transmission has seen actual street use other than trial runs down our dead end road. Well, the slider we modified for 1-2 did not hold up real well. I down shifted a little too early to make a corner and it never felt right after that. I dicided to try a WOT shift from 1-2 and this is what happened
Busted all the lugs of the slider clean off. So we dicided to go back to the drawing board and do the same thing we did for the slider for 3-4. Only this time we were just going to have the center splined to match rather than mating the splines of the factory slider to the new piece, but no one would get back to use about it and I got tired of waiting.
Machined factory slider
Machining new slider
New slider and old splines mated together
As you can see, we also decided to upgrade from 4 lugs to 8 and also made them thicker since 2nd gear takes more abuse as far as load with down shifting and also starting the burnouts in 2nd
The trans does have to come out this winter. The slider we made for the 1-2 didnt have enough clearance and doesnt allow me to do a WOT shift into 2nd. So it will be getting a little machining done to open it up a little
Once after it first went out. We converted it to a crash box but the teeth failed, then another beginning this process, then when the fork and last time when the slurred broke so 4 times
Lets just say that I have taken it out enough where when I broke the slider, I drove it home skipping 2nd gear, put it on the lift, and had it out and tore apart less than an hour later
Thanks. I thought about giving up and putting stock gears back in. After sitting back and realizing all the work that has been done already, I figured I have come to far to just give up. After fixing the slider Im sure it will be fine
