Drag Racing Tech
QA1 Rear Shocks... Single or Double Adjustable?
Old Nov 5, 2012 | 04:18 PM
CamaroRacing12's Avatar
Default QA1 Rear Shocks... Single or Double Adjustable?
I can get a killer deal on single adjustable rears.... are double adjustable worth it?
Old Nov 5, 2012 | 04:22 PM
Zmg00camaross's Avatar
If its auto single adjustables would work just fine IMO.
Old Nov 5, 2012 | 04:31 PM
worddd
Old Nov 5, 2012 | 05:29 PM
zracer323's Avatar
How fast are you looking to go with them?
Old Nov 6, 2012 | 08:27 AM
low 12's high 11's
Old Nov 6, 2012 | 08:29 AM
St Louis SHO's Avatar
Did that on wore out stock stuff.
Old Nov 6, 2012 | 08:30 AM
Yes singles would work fine. There guys on here running 9s with m6 and single all the way around.
Old Nov 6, 2012 | 09:22 AM
Camaro9969's Avatar
If your going to run 12's or high 11's you could get away with pretty much anything.
Old Nov 6, 2012 | 10:08 AM
SS SLP2's Avatar
chk your PM,s
Old Nov 6, 2012 | 10:09 AM
Yeah big guy? did you do it with a bone stock bolt on only LT1?
Old Nov 6, 2012 | 04:17 PM
redcam622's Avatar
Default shocks
Ran single adj. to low 7s and 200mph..1.17 60' on radials
Old Nov 6, 2012 | 04:36 PM
Never said your setup. Mine *was* a cam/converter full weight convertible. 180k on the clock, stock suspension. 1.57 60' on 275/40/17 ET streets.
Old Nov 6, 2012 | 05:59 PM
ramairws6's Avatar
Man, that was a steel!
Old Nov 12, 2012 | 08:23 AM
a cammed ls1? going high 11's should be easy with that setup.
i snugged a set of rear QA1 single adjustables for $150 shipped thanks SLP and got my eyes set on seom fronts as well.
