Drag Racing Tech
1LE LT1 drag project build thread
Old Jan 20, 2013 | 08:12 PM
1961ba427's Avatar
I will have a 33 spline spool coming out of my 12 bolt to swap to a posi soon. My car is pretty much all street and daily driver these days and it's getting old dragging my tires around every turn in parking lots. It gets me some cool looks though. LOL The 4.10's in mine are louder than any gears I've ever heard so they have to go too, but I'm sticking with the same ratio. I've got all the parts I need except a new ring/pinion.
I'd try sticking with the 4.10's and go with a 28x10.5-S slick. The "S" after the 10.5 is for stiff sidewall. It'll work better with cars over 3,000 lbs. If you go with a 26" slick then you'll probably need to swap to 3.73's. Hopefully you won't run out of track before you run out of rpm when you are spraying. People with more nitrous experience can advise better here.
4u 2 nv's Avatar
FWIW....i weighed my 94 1LE with no spare tire and jack and it weighed 3230.....that car for a stock LT1 rolled out lol. wish i hadnt sold it.
Old Jan 20, 2013 | 08:17 PM
1961ba427's Avatar
I know the 1LE is a performance / stripper style package, but I don't even know what it consists of for 4th gens. I was very familiar with the 3rd gen 1LE's. My 1989 Formula 350 had everything they had except for AC delete, radio delete, and the big front brakes.
What all made up the 1LE to make it so much lighter for 4th gens?
Old Jan 20, 2013 | 09:26 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
what r u looking to get for the trans?
Old Jan 20, 2013 | 11:05 PM
Jason94z's Avatar
No anything lol
Crank windows, manual seats, no ac, no fog lights, etc etc.
sorry sold it
Old Jan 20, 2013 | 11:06 PM
Jason94z's Avatar
I found a spool in the classifieds if that falls through I'll buy yours let me know
Old Jan 20, 2013 | 11:11 PM
Jason94z's Avatar
Also, you might want to think about going from the posi to a full spool since you are going to be drag only. Less rotating weight/bulletproof/always wants to go straight. You can pick one up new cheap....or used even cheaper as long as you know what spline your axles are. Your posi unit will sell for more than enough to pay for the change.
I wish you'd make a duplicate thread over in the LT1 section on here. Plenty of people who are on the same road as you or already there to talk to and learn from.
I found a used spool with the right spline
What else do I need - I currently have c clips do I need an eliminator kit and new axles?
Ill come check out the lt1 section thanks!
Old Jan 21, 2013 | 12:47 AM
1961ba427's Avatar
Are you sure you still have c-clips? All the aftermarket 12 bolts built for our cars I've seen have had bolt in axles with pressed on bearings like 9" Fords. If your axles are retained by c-clips you will need c-clip eliminators or bolt in axles and possibly different housing ends to accomodate them. I'm betting your axles bolt in like a 9".....and like the strange and moser 12 bolts I have.
Old Jan 21, 2013 | 12:43 PM
studderin's Avatar
not having Cclips dosn't really make the axle any weaker, ther no stress on the end past the spines inside whatever diff you have. And if you have disc brakes on the rear, if you do break an axle the caliper over the rotor will keep the axle in the reared on the bearing, and not let the tire damage the car. So you really dosnt need them for what your doing for safty. Even if it's not NHRA legal, for a buget setup to have fun with. You can make a little metal arm on a drum brake that holds the drum on, but only works if you have rim room there. Ive seen that setuo too for super budget stuff to have fun with.
this looks like if could be a fun project, keep it simple
Old Jan 21, 2013 | 08:38 PM
1961ba427's Avatar
I mentioned bolt in axles or c-clip eliminators because there is no place to install c-clips with a full spool. I've used c-clip axles with posi units for years in old chevys and only had one axle failure....and that was a 6k rpm clutch dump on stock axles. LOL
Sure a caliper will keep the axle from leaving the rearend with a full spool, c-clip axles, and no c-clips.....but the axles would constantly be pushing out against the brakes while under power or cornering. They shouldn't be able to slip in and out of the spool several hundredths of an inch like that. I wouldn't trust it.
Old Jan 21, 2013 | 09:43 PM
4u 2 nv's Avatar
like mentioned..no power options. No PW, PDL, No fogs, No A/C. Not even a power truck release. All got the base radio. Cloth interior. They also got different sway bars (IIRC 32/21 F/R). Different struts and shocks. Most will claim that all got poly bushings even as far as the trans mount etc. In LT1 cars, you could option Koni SA/DA...but they brought back the A/C as a standard option in 96 or 97 to help with sales. Unknown to most..they 1LE could also be optioned with an auto.
Some guys do the basic stripping setup...bumper supports, seatbelts and backseats, etc and dont have much of a problem getting down to 3000.
Old Jan 21, 2013 | 11:28 PM
  #32
studderin's Avatar
1961, right, I didn't even think about that! lol
Old Jan 22, 2013 | 05:37 AM
  #33
bufmatmuslepants's Avatar
My car is a base 94 z28, and with only free mods for weight reduction and no cutting, I was 3010 still with stock bumper supports, no trimming to wiring, a cat back, and 2 stock front seats, one with power, and salad shooters with street tires, and mild steel suspension. You shouldn't have a problem if you take your time and take advantage of every mod. I think your high race weight right now is what is killing your et. What is your compression ratio?
Old Jan 22, 2013 | 09:51 AM
  #34
Camaro396's Avatar
You can sell me that Mufflex exhaust system. Your drag car doesn't need exhaust
Old Jan 22, 2013 | 11:20 AM
  #35
toolpimp's Avatar
If you are interested in used 9 inch bolt in I know where there two for sale one with spool an one posi chuck burkhart sold these guys new rearends an they need to sell there old ones. email me jimmy.turner1968@gmail.com
Old Jan 26, 2013 | 06:12 AM
  #36
Jason94z's Avatar
I called moser and you are correct I'm good to go!
11.5 to one from memory, I will have to dig up my engine build from the 1990's to be sure. Man that's a long time ago
I was going to but when I took it off to drop the M6 a few weeks ago it was pretty light. And it sounds SOOOOOOOOO sweet.
Old Jan 26, 2013 | 06:13 AM
  #37
Jason94z's Avatar
Thanks - when this blows up I'll get a fab9 or something light
Old Jan 26, 2013 | 06:14 AM
  #38
Jason94z's Avatar
Yeah! Scored a 33 spline spool for my 12 bolt
while I'm in there I may change gears from the 4.11
I need to estimate my MPH and do some calculations
Old Jan 29, 2013 | 03:25 PM
  #39
Jason94z's Avatar
Just got off the phone with Troy at FTI.
Does a stage 4 trans and an 8" converter sound nice?
Old Jan 30, 2013 | 04:20 PM
  #40
Jason94z's Avatar
FTI!
I ordered the transmission today. I'm excited. Troy says it should be here in a week or two.
Stage 4 TH400 with a trans brake and rmvb
5500 8" stall, will stall higher on spray
CSI carbon fiber shield
Lokar dipstick
Pan is tapped for temp guage
6an cooler lines
Cooler
The sheild and dipstick blew my budget a bit, so now I need to save for wheels (again).
