Drag Racing Tech
1LE LT1 drag project build thread
Old Jun 7, 2013 | 02:30 PM
  #61
Jason94z's Avatar
Originally Posted by am_muscl
Is that Vaseline by the transmission?! Hahaha gotta lube it up. This is pretty fun to watch I'm looking to get mine to around 3000lbs with me in it without cutting fenders. Keep up the good work
Lol yeah I didn't have any grease for getting the old pilot bearing out so I used Vaseline hehe
Old Jun 8, 2013 | 02:10 AM
  #62
Turnin20s's Avatar
Why not cut fenders? I can tell you that after cutting mine out I have no worries as far as safety is concerned, they would not do anything to help in a crash if that is why you aren't cutting them. But I'm not telling you what to do, it's your car in the end I cut 10.3 lbs out IIRC of my front fenders, I could have cut out another 1-2 lbs but I didn't think it was worth the extra effort at this time, I'll save that for later down the road.
Progress looks good man. keep it up
Old Jun 8, 2013 | 05:01 AM
  #63
Jason94z's Avatar
10 lbs?! Where do I cut?!
I just did a quick search, do you have a pic handy?
Thanks
Old Jun 8, 2013 | 07:53 PM
  #64
Turnin20s's Avatar
Old Jun 8, 2013 | 08:03 PM
  #65
Turnin20s's Avatar
I took a little weight out of the lower rad support too, I had to keep the mount for the air dam since I have a street car
And a bunch of interior brackets
Sorry don't mean to hijack the thread, but just trying to help you out. I took about 600 lbs out of my car this winter so if you need anything else let me know, I took a bunch of pictures.
Old Jun 9, 2013 | 06:50 AM
  #66
Jason94z's Avatar
Ah man I just put the front end back on
Thanks for the pics. Next winter I buy new sawzall blades and spot a spot weld drill bit!
Old Jun 9, 2013 | 08:51 AM
  #67
Jason94z's Avatar
Door Panels 9.5 each 19lbs
Total 253 lbs out
Anyone have a 1-2 lb solution to put back on the doors to make them look nice again?
Now for the #$% bars... not looking forward to it ... I'm not the most patient guy wielding a wrench...
Old Jun 9, 2013 | 11:08 AM
  #68
Turnin20s's Avatar
I thought about doing this to my doors
https://ls1tech.com/forums/drag-raci...oor-panel.html
Old Jun 10, 2013 | 05:06 PM
  #69
Jason94z's Avatar
That looks great
Hmm
I'll leave them off totally this season to ET it then I'll put some back to make it look nice over next winter. It only has a few thousand miles on it so the car is mint, be a shame to have it LOOK like a racecar... I'll figure something out
Old Jun 10, 2013 | 08:05 PM
  #70
studderin's Avatar
fyi ai cut3 up my lower rad support to just have 3 bolts, and its been fine for many year.
Old Jun 11, 2013 | 07:19 PM
  #71
Jason94z's Avatar
Yeah next winter is cutting, this year it's almost July and my pile is still on stands! I need to get cracking
Where are you guys putting your 1" spacer for TH400 using the M6 mount, A or B? (On top or under?)
Old Jun 11, 2013 | 10:10 PM
  #72
1961ba427's Avatar
From what I understand it's "A" between the mount and the transmission. I think it may be more than 1" thick though. Spohn sells a spacer for about $30.
Old Jun 11, 2013 | 10:32 PM
  #73
Jason94z's Avatar
Googled, found, and ordered!!! Thanks a million man!!!
Old Jun 12, 2013 | 12:07 AM
  #74
1961ba427's Avatar
You're very welcome. Glad I could help you out. I actually just saw it on Ebay for the first time a few days ago and had stuck it on my watch list for future reference. LOL
Old Jun 12, 2013 | 01:04 PM
  #75
Jason94z's Avatar
Started the studs today:
Edit: They are Arp 12mm late model GM .509" knurl 3.25" length and fit perfect, for anyone that's googling
Old Jun 12, 2013 | 01:23 PM
  #76
Turnin20s's Avatar
Boy aren't those fun lol, after I got done with mine and bolted the wheels on I got to take it all back apart and install new ones because the closed lug nuts were too short and buggered up the ends I only use open lug nuts now
Old Jun 12, 2013 | 01:35 PM
  #77
Jason94z's Avatar
Doh! I'll be sure to get all open for sure thanks.
Well, it's almost time to get wheels. There's some Prostars for sale but they have Goodyear rubber (I want Hoosier = lighter) and there's some Draglites for sale, but they have drag radials and street tires on the front.
So it looks like I may have to ring up Jegs. I'm 99% set on Draglites, but when I see pics I flip-flop. Argh. I'll have to make a decision soon.
This is the look I'm copying, love it. I know most like the prostars but check out the draglites. Argh I should just flip a coin. LOL.
The competition:
Old Jun 12, 2013 | 01:42 PM
  #78
LS1rob00's Avatar
Draglites look like poop, get ProStars lol
Old Jun 12, 2013 | 01:54 PM
  #79
Jason94z's Avatar
You sir, have been put on ignore.
J/K
Man I just looooooove them both. My 8 year old says it's easy, put Draglites on the front, and Prostars on the back, problem solved. LOL.
Old Jun 12, 2013 | 02:15 PM
  #80
Jason94z's Avatar
Ok looking at these charts I may have been wrong on the Hoosiers being lighter, they look the same to me for 28x10.5
http://www.hoosiertire.com/specdrag.htm
http://www.mickeythompsontires.com/s...hp?item=ETDrag
