1LE LT1 drag project build thread
Transmission hump padding 3.5 lbs
Total so far 263 lbs out
It is taking more and more work to get out less and less weight now. Heh. HVAC is next. I already don't have AC (1LE) so I wonder how much the HVAC will even save me. At least it will clean up the engine bay.
I did not take off the part form the calipers yet, too far behind to start a new project
Got all the wheel studs finished today too. Had to pull the axles to do the rears.
Old one:
Finished new one beside the old one:
all the stuff out weighed 22 lbs
new bracket it weighs 2 lbs
Saving net 20 lbs
Total so far 283 lbs lighter!
Anyone know where the oil leak is in the last pick? Please don't say front intake, please don't say front intake!
Before:
22 lbs of junk:
Relocation bracket and belt 2lbs:
Uh Oh found a leak. Is this intake? Anyone?
I will clean it off and see what happens.
No drips on the garage floor so that's good I guess it only seeps while running.
Door bars: 16 lbs for both
Total out so far: 299 lbs
I had an E-brake cable break on me a few weeks ago, and being an M6 I need to fix it soon. It made finding a parking spot in the mountains on vacation last week a challenge. LOL
Also, if you can find anywhere to save your old heat only HVAC parts.....I'm sure that will be a highly sought after item in the near future....or if you ever decide to restore or sell your 1LE.
I've bagged and stored that stuff. I meant ripping stuff out of the car, not actually throwing it in the garbage. Sorry for the exaggeration. I'm the original owner and it only has 8,000 miles on it, oiled and stored indoors so everything is mint. It won runner up in a car show just with a wash so no worries here, it's all staying neat
First clean off the paint and make sure the convertor fits in pilot hole - it does!
Then fill convertor
Then stand transmission on end and spin the convertor on - it clicks and drops 3 times. Measure and it's all good!
Tilt and slide under car.
Too bad it's time to go to a couples wedding shower now argh I was so close
If the torque convertor didnt fall out once under the car, making me start all over again, I might have a couple bolts on it by now. Heh. Maybe tomorrow I can get it in all the way. The torque convertor kept falling out when I would lift the tail a bit, and I got tired of sliding the whole transmission out to install it again. So I just installed it back while it was under the car, and I'm not exactly sure if I got three clicks or two. It's in pretty deep, and measures properly from case to torque converter mounting pad, so I guess it's ok?
I put a piece of wood inside the shifter area, and hung a wire to help with muscling it in.
Then I kept rocking it back and forth stacking 2x4's to get it high enough to get my jack under. As soon as my jack was under the rest was "easy".
