Drag Racing Tech
1LE LT1 drag project build thread
Old Feb 27, 2013 | 02:36 PM
  #41
Jason94z's Avatar
Transmission came today!
Customs was slooooooooow
But it's finally here
Old May 5, 2013 | 04:58 PM
  #42
Jason94z's Avatar
Progress!
I replaced the rear main seal,
and put on the flexplate today.
Now I just need to jack the TH400 in there and get the driveshaft made.
Old May 25, 2013 | 03:06 PM
  #43
Jason94z's Avatar
I kept staring and staring and it just wouldn't go in.
I guess I need to work the jack up a bit higher and try again
Old May 25, 2013 | 11:43 PM
  #44
Turnin20s's Avatar
Nice build, looks like you are headed in the right direction. I'm subbing to see what it runs, should be a fun ride with a 200 shot
Old May 26, 2013 | 02:49 AM
  #45
82cetuner's Avatar
time for some strang or aero space brakes for some super weight reduction, and seats to who needs them
Old May 26, 2013 | 08:04 AM
  #46
Jason94z's Avatar
Budget dictates stock brakes this season but I keep looking online and resisting.
Realistically I need to start getting the car back together or it's going to be winter time again and I'll have one of those never-run 5 year track car projects. I need to hit the track soon or I'll freak out LOL
To get there this year I'm skipping stuff like installing the spool. I'm going to run the posi 4.10's until I see where my mph is at, then, I can choose the right gears and go to a spool then. At the same time I can then drill the axles out for 5/8 or 1/2 studs, get the rear drag brakes etc.
So I decided to reverse the dismantling mode and start just putting the car back together to get some runs in. I can always do a mod at a time later while it's running, rather then keep striping down to a 5 year project
Old May 26, 2013 | 10:27 AM
  #47
1961ba427's Avatar
Originally Posted by Jason94z
Realistically I need to start getting the car back together or it's going to be winter time again and I'll have one of those never-run 5 year track car projects. I need to hit the track soon or I'll freak out LOL..........So I decided to reverse the dismantling mode and start just putting the car back together to get some runs in. I can always do a mod at a time later while it's running, rather then keep striping down to a 5 year project
I think this is a wise move. This is exactly why I have stopped doing anything with my LT1 cars and started back on my 61. It's been sitting too long and that's a shame. Hoping to see results from the track soon.
Old May 26, 2013 | 03:51 PM
  #48
Jason94z's Avatar
I ripped out 156 lbs today in an hour! Anyone need a PERFECT graphite interior with just a few thousand miles on it? Carpet just has leaves on it, vacuum and it's perfect too.
Floor mats 9
Grey cloth manual passenger seat 31
Grey cloth manual driver seat 36
Fire extinguisher 8
Rear cloth seats and belts 29
Rear flappy thing and carpet 6
Carpet with padding 31
Console 6
Total today 156 lbs. It was easy!
Old May 29, 2013 | 04:23 PM
  #49
Jason94z's Avatar
Got my wideband o2 bung welded on today,
and I removed the front swaybar and brackets for 15.5 lbs
Total so far 171 lbs removed.
Old May 30, 2013 | 08:15 PM
  #50
Jason94z's Avatar
Front bumper support 24 lb
Horns 2.5 lb
Washer and fluid I had in it 4.5 lb
Total so far 202 lb removed
Old May 31, 2013 | 11:38 AM
  #51
Jason94z's Avatar
I'm cutting the bumper support like this so the front end won't flap down. Anyone else done this?
Old May 31, 2013 | 12:15 PM
  #52
Turnin20s's Avatar
That won't do anything to stop the bumper from flapping if you cut it like that. You will just waste some cut off wheels and time to add some weight back in. The honeycomb presses up against the bumper to hold it from flapping so you need to add something back in there if you want to. Lots of guys get some aluminum from home depot and build something or you can get some MWC supports like I did.
Old May 31, 2013 | 12:21 PM
  #53
Turnin20s's Avatar
*edit*
After I looked at your pics again that is the bottom of the bumper support right? You could cut that up and keep the bottom from flapping, but I think you would be a lot better off with a couple of aluminum straps to do that same job for a lot less weight, or just trim that part off of the bumper cover and save a couple more pounds
Old May 31, 2013 | 02:28 PM
  #54
BSmiff's Avatar
Looks good so far. I need to start gutting my pig.
Old Jun 2, 2013 | 08:32 PM
  #55
Jason94z's Avatar
Ok I did it anyhow and I like the way it turned out. It doesn't support the center point of the bumper in anyway but it does support the bottom. My main deal was those three press in hole things that now work again. If it's not good enough and starts drooping I'll have to order the real deal but for now here is how it turned out. It only added back in 1.5 lbs, and, I removed my alarm horn that was under there and the front licens plate for 2.5 lbs so I am still down another pound today
I only had brown rust paint today but it's all hidden so I just shot it and installed it:
Old Jun 2, 2013 | 08:53 PM
  #56
Turnin20s's Avatar
Looks good man
Old Jun 2, 2013 | 09:55 PM
  #57
studderin's Avatar
I cut the flap off, were it just gose back up to the bumper support. All the weight is held up with aum bars in the middle on the nose. And 2 going to the lower ends, but more for the front corners of the wheel well openings. that looks like it works good, you still have the frame horns and alll that
Old Jun 5, 2013 | 10:04 PM
  #58
Jason94z's Avatar
Thanks man
This is just round 1 - every year I'll dig more into it and I'm sure when I get a pin on the front frame rails will get chopped back more
Rear support today 20 lbs.
Total so far 222 lbs removed.
I started at 3416 lbs I'm down to 3194 lbs.
My 17" wheels and rubber was 220 lbs and I sold those, so technically I'm at 2974 with no wheels
Old Jun 6, 2013 | 08:17 PM
  #59
Jason94z's Avatar
Today wipers and motor 12.2 lbs
Total so far 234 lbs
Old Jun 7, 2013 | 01:59 PM
  #60
am_muscl's Avatar
Is that Vaseline by the transmission?! Hahaha gotta lube it up. This is pretty fun to watch I'm looking to get mine to around 3000lbs with me in it without cutting fenders. Keep up the good work
