Here's a Diagram For Battery Relocation
I've seen alot of different ways people are doing this. Some good, some bad and some wrong.
IMHO, I think this is the correct way of doing this.
You will need some #1/0 awg for the battery cables. I like weilding cable,
it's very flexible.
Some #4 awg for everything else. Automotive Wire would be nice.
Cut-Off Switch of your choice.
I like to put a 150-200 amp fuse on the ground side. This fuses the whole
wiring system.
This way, when you push your cut-off switch, it kills the whole system.
I hope this helps.
He had a rod that connected to the switch in the trunk that was removable (rod only) when not at the track. The rod went through an existing bolt hole.
I'm pretty sure if you looked hard enough you could come up with somewhere.....like maybe behind the rear tag (remove at the track) or through the rear tag ??? just thinking out loud.
and of course a 0/1 engine to chassis ground.
I also grounded the motor to frame with a 1/0.
#2 wire is cool, just an upgrade from #4. Either will do the trick!
I have thought about it many times and that is about the only way I can think of doing it that I would be happy with. I don't like the looks of the big *** rod sticking through the panel or the tail light.
He's a pretty smart guy when it comes to electrical wiring so I have no reaso to doubt him.
Just figured that would be a way of saving Money/weight by running a 16gauge wire instead 4ga cable the whole length of the car to accomplish the same thing In the end.
And the point of the alt cable going back that far is to insure that the battery actually gets charged(from what ive read)
J-box. I like only one wire on my starter. Very little room around the starter.
The 1/0 wire is alittle overkill on the starter. But if you like the more "proper"
way. That's cool.
very nicely.
I think he was talking about the exciter wire, not the actual charging cable.
