VIDEO of my launch help**** NEW VIDEO WITH N2O post #72
#45
its hard to tell from the distance, but it looked like it may have spun? but the engine sounded sluggish launching. I may have missed it in the thread already. What was your launch RPM there? What does it footbrake to again? what psi in the tires?
#46
sorry, im kinda just thinkin bout where most engines powerbands are, peak torque is probably no where near 4500-5000 revs so why run one with a stall that high? i was thinking having a converter with too high of a stall is like slipping the clutch in a stick car until the 4500 rpm, like the point of stall speed if you get what im saying. i wanna see the new video with the 150 shot
#47
#50
You were asking about the drag bar... I have the Wolfe drag bar setup on my 9 inch, and I am really impressed by it. This thing is SO stiff. There is no more side to side flex at all. When I back my car out of the driveway it has to go over a little hump before it gets on the street and it always pulls a tire off of the ground getting out of the driveway. That's how stiff it is.
At least for me... Steel spool in the rear end + Wolfe drag bar = Launch straight and true EVERY time! Very glad I got this setup.
#51
I really think the shocks worked and calmed the twisting down a lot so idk if I really NEED one right now and I don't think it will be that beneficial to lowering my short times at this time
#56
I got to thinking today at work and idk if I'm just thinking stuff up so let me know if this is possible
Before with other trans and rearend I had 26" tires and it dead hooked.... Now I have diff trans and rearend with 28" tires
My thought process today was I have my torque arm mounted in the middle hole on relocation xmember... But since I went to a taller tire wouldn't I need to raise my TA higher on the xmember?
My pinion angle has always been at negative 2... Before the swap and I reset it after swap
It's just a thought ...
#58
ok so I went to track last night and sprayed
this is the first pass and I sprayed straight out of the hole and spun
1.7 60ft
1.7 60ft
